moving tractor with new truck
   / moving tractor with new truck #1
heehaw
russellville, arkansas
Kubota M4900, B7510 and RTV
i have to admit, i was a little concerned when i bought my new GMC truck, and the biggest motor i could get was a 327, in the half ton model...i have been use to the 350 in my 93 GMC..but i moved my M4900 kubota tractor last night, and it did a good job, handled the load with no apparent problems..
still need to install the brake unit...i think i'll do that before i move the tractor again...i don't mind not being able to go, but i get real excited when i can't stop...
heehaw
   / moving tractor with new truck #2
Yeah I agree on the trailer brake idea. I just bought a new Dodge Ram 2500 with the Cummins turbo diesel. I'm guessing it should pull my Kioti 3054 just fine /forums/images/graemlins/wink.gif
   / moving tractor with new truck #3
Did you get the HO cummings or the standard ? Dave
   / moving tractor with new truck #4
heehaw,
I think you'll like the 5.3 liter (oops I mean 327) motor. It has more horsepower and similar torque to the 350. I have it in my 00 Chevy z71 and it is quite capable. It's definitely got more power than the two trucks I have at work with stock 350's.
Of course, the 6 liter is noticeably better when a load is on the back. /forums/images/graemlins/wink.gif
   / moving tractor with new truck #5
My '01 2500 quadcab 4x4 Cummins pulls a Bobcat S185 just fine. That's about 7800lbs.
That is above the reciever hitch rating for towing with a compensating reciever system though, which is rate to 10,000 lbs. Normal tow rate on simple ball reciever is only 5000lbs
   / moving tractor with new truck #6
<font color="blue"> I don't mind not being able to go, but I get real excited when I can't stop... </font>
No sense of adventure? /forums/images/graemlins/grin.gif
   / moving tractor with new truck #7
You don't have to worry about the truck not being able to work. I have a '99 Silverado w/ 71k on it and I've worked it plenty hard. I've towed 32' campers w/ it weighing at about 8k. I've towed a trailer hauling a Ford 3000 & 5' bushhog. Probably the most weight I've actually towed is my cousin's Toyota skidsteer. It is pretty good sized one. I think he said it weighs a little over 8k + 800 pounds for the bucket + about 1500 for the trailer. That doesn't take into account the fact I had the bed loaded down with all kinds of tools and such as at that time that was my storage shed. I think I also put some other stuff on the trailer too. Maybe including my Dad's old Sears garden tractor. Had it squatted pretty good but power & braking (brakes on all 4 trailer wheels) was fine. Would I want to travel across country this way? No, but the 20 or so miles each direction I was traveling it was fine.
Currently I'm working on building the pole barn and I'll throw a ton of limestone/sand mix in the bed and throw another ton on my little 2 wheel trailer. The trailer squats pretty good, but the truck is fine. So much for not being able to work a half-ton short bed. /forums/images/graemlins/laugh.gif
i use a reese equalizer hitch when hauling my tractor, or anything else heavy on the flatbed trailer..have hauled it twice more since i started the thread, and i am very satisfied with the way it handles the load..i think it does better than the 93 GMC with a 350 motor....still gotta get the brakes hooked up!!!!!
heehaw
   / moving tractor with new truck #9
I have an 01 Dodge HO Cummins diesel and have a Bri-Mar 18 ft, 12,000 GVW trailer. I did have to change the receiver and upgrade to a 1100 lb tongue weight. It pulls my Mahindra 4110 w/Bradco 11 ft hoe, with no problems what so ever.. Of course brakes, both trailer axles are nice. They are also mandatory here in CT. New Enlgand tractor, the dealer I bought from, is right close to 100 miles from me. 95% I 84 up and down hills non stop. The Cummins don't even feel that trailer/tractor combo..
2007 Chrysler Aspen SUV (A56859)
2007 Chrysler...
2007 KAWASAKI MULE 3010 UTV (A58375)
2007 KAWASAKI MULE...
2206 (A58376)
2206 (A58376)
1602 (A58375)
1602 (A58375)
SKLP Pipe Crimping Machine (A57149)
SKLP Pipe Crimping...
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
