Moving the fuel pump on a 422/425
   / Moving the fuel pump on a 422/425 #1
MuncyBob
Platinum Member
N Central PA
PT 422
It makes sense to move the fuel pump to an area of less heat. For those that have done this, where did you relocate it to? Does the location need to be an apprx same height as original location in relation to the carb or fuel tank outlet?
   / Moving the fuel pump on a 422/425 #3
I removed the stock pump and installed an electric as far away from the exhaust heat as possible.
My vaporlock problem still existed but not as much. It only was completely cured when I installed the large fan on the engine cage.
http://www.tractorbynet.com/forums/power-trac/99371-pt422-aux-cooling.html
Phil
My vaporlock problem seems to be cured by a combination of electric pump, insulated fuel lines, and using only premium fuel. I went all last summer and this winter with no problems.
UNUSED WOLVERINE 66" BOLT ON PALLET FORKS (A51248)
UNUSED WOLVERINE...
Trojan 5T-45 36in Hydraulic Thumb Excavator Attachment (A51691)
Trojan 5T-45 36in...
2017 Kia Sedona LX SUV (A51694)
2017 Kia Sedona LX...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2017 MORBARK BEEVER M12RX PORTABLE WOOD CHIPPER (A51247)
2017 MORBARK...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
