Moving the fuel pump on a 422/425
   / Moving the fuel pump on a 422/425 #1
MuncyBob
Platinum Member
N Central PA
PT 422
It makes sense to move the fuel pump to an area of less heat. For those that have done this, where did you relocate it to? Does the location need to be an apprx same height as original location in relation to the carb or fuel tank outlet?
   / Moving the fuel pump on a 422/425 #3
I removed the stock pump and installed an electric as far away from the exhaust heat as possible.
My vaporlock problem still existed but not as much. It only was completely cured when I installed the large fan on the engine cage.
http://www.tractorbynet.com/forums/power-trac/99371-pt422-aux-cooling.html
Phil
My vaporlock problem seems to be cured by a combination of electric pump, insulated fuel lines, and using only premium fuel. I went all last summer and this winter with no problems.
New/Unused Two Post Car Lift 10,000lbs (A51573)
New/Unused Two...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
PAIR OF 5' PIN ON FOLD UP RAMPS (A51247)
PAIR OF 5' PIN ON...
HYD PUMP & TANK SET (A51248)
HYD PUMP & TANK...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
