Moving round bales without a spear??
   / Moving round bales without a spear?? #1
clovergamecock
Clover SC
Kubota L2800 4WD FEL
The dairy company that I provide hay to just finished baleing it into round bales. They usually leave me 3 or 4 bales depending on what I want\need. Sometimes I am home and can catch them and they will take the bales to my barn with their skidsteer and spear. I was not able to give them access this time so now I need to figure out a way to move them without busting them open which I have done in the past.
I don't get enough hay to justify a spear purchase so I have done eveything from pushing or dragging with my Kubota L2800 w\FEL to tieing straps around them and trying to lift with my bucket. The straps just stretched.
Any suggestions?
Thanks
Wade
   / Moving round bales without a spear?? #2
With the bucket lip under the edge of the bale you may be able to loop a ratchet strap around the bale and back to the lift arms at the top of the curl cyl mounts. Ratchet tight to pull the bale in as far as possible - then curl a little and ratchet some more, etc. You can probably establish a balance this way. Then lift it an inch and drive where you need to go. Be sure to have some counterweight on the tractor.
larry
   / Moving round bales without a spear?? #3
I' try Larry's idea, if that didn't work, maybe some type of "skid" to roll the bale onto. A piece of tin? Sheet of plywood, something you can lift a couple inches and pull.
   / Moving round bales without a spear?? #4
A stronger strap . A 3" wide one would have no problem doing what your doing .
   / Moving round bales without a spear?? #5
Get a spear or prongs. Ask the local rural fire department how often somebody rolls a round bale down the loader onto themselves.
   / Moving round bales without a spear?? #6
If ya strap it to the bucket right it can't go anywhere . And if ya just raise it enough to clear the ground there's no way a bale is going to jump on u on the tractor .
   / Moving round bales without a spear?? #7
I agree with Western. Build a sled, roll the bales on it and drag them.
   / Moving round bales without a spear?? #8
L2800 ... Round bale ... raising the bale high enuf to roll down the arms? There would be many prior clues that something was wrong.
larry
   / Moving round bales without a spear?? #9
We have a 5x10 tilt trailer with a solid steel floor that works OK for one bale at a time.
Today we would use a set of our chain on forks.
   / Moving round bales without a spear?? #10
Tractor supply i believe sells a cheap carry all that mounts to the three point. Should be enough to get done what you need.
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
