Moving rocks
/ Moving rocks
Hey; it worked. been having a hard time to figure out how to resize pictures.
Egon
/ Moving rocks #4
Take yr pics with the highest resolution you can...at least 800x600 if yr cam has that. Once you dump the pics to yr computer, you can right click and select properties. If it's less then 150Kb, you can post as is. If it's larger, you have to resize. Go to www.irfanview.com and download their free image software. Open the pic with Irfanview, then go to IMAGE-RESIZE/RESAMPLE and select a lower resolution.
By the way, some digital cams save the pics as .bmp files. Although a .bmp is higher quality, it takes up a lot of space. The same image (a 150Kb .jpg, for example) might be 8 to 10 times larger (getting into the Mb size now, Egon). If it's a .bmp, just open it (using Irfanview) and save as a .jpg
/ Moving rocks #5
Those little mules don't no when to quit. /w3tcompact/icons/smile.gif
/ Moving rocks #6
EGON; u call that a rock? have had bigger than that stuck in the tred of my tires,/w3tcompact/icons/smile.gif of course u know that i am funning with u?
/ Moving rocks #7
<font color=blue> Kinda small.../w3tcompact/icons/smile.gif </font color=blue>
The rock? The picture? The tractor? /w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
O.K. what did you do with the rock once you had it lassoed?
/ Moving rocks
Roy:
I don't have a digital camera. These were photos that had been put on a disc. The originals were way to large to post and with my limited computer [ read non existentant ] skills it took a long time to figure out how to resize.
Thanks for the information.
Egon
/ Moving rocks
Thomas:
The " little mule " also moved the rocks beside it up a 15 degree slope.
Egon
/ Moving rocks
Big Dave:
The guy taking the picture is kinda small too.
The rocK is slate and will be split into thinner sections for use in the lakeside camping area.
Egon
/ Moving rocks #11
Cool picture!
You know not to used slate in a fire pit, right? It can explode.
Great stuff for landscaping, though.
/ Moving rocks
Actually, I don't have a fire pit. What I have is what I call a fire hill. It is composed of 5 slate rocks about 10 in. thick raised 16 inches above ground level. Its about 5ft. by 10 ft. No problems with exploding slate so far and there have been some real nice fires. Used the tractor loader to bring in the wood. The setup doesn't allow the the base to get all that hot and allows lots of air for a good fire. It's also a good place to dry wet boots and warm the feet on a cool evening.
Egon
/ Moving rocks
Here's a picture of what the slate is used for.
Egon
/ Moving rocks #15
I can see a large coffee pot and big skillet with bacon and eggs frying … this is a beautiful place … and I’m sure you are very proud of it …as you should be …
Leo
/ Moving rocks
Yea; we kinda like it. Only how's about a fresh morning caught trout instead of the bacon.
Egon
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
7002SFL (A61572)
7002SFL (A61572)
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
Unverferth Assist Wheels (A64127)
Unverferth Assist...
Peanut Wagon (A64127)
Here are some similar links:
  • Article
  • Type: Construction
Replies
0
Views
62
  • Article
Replies
0
Views
86
  • Article
Replies
0
Views
61
