moving large squares
/ moving large squares #1
rope1250
Western Iowa
Massey Ferguson 1660 Dyna QPS
Any body have any experience moving large squares with a single spear designed for round bales? Not moving many, just buying a few since we can't get any small squares around here right now.
/ moving large squares #2
The bale slides down around the spear because the hay pieces aren't oriented in a circular fashion. Won't work well, but will work better with strings at sides, not top and bottom.
/ moving large squares #3
Could it be speared through the end of the bale?
/ moving large squares #4
We use to get tractor trailer loads of big squares and handled them with a standard round bale spear. Would pick up two at a time with big tractor.
/ moving large squares #5
Local dairyman handles big square bales with a regular 2 spear rd bale mover.
/ moving large squares #6
If you have a welder you could weld 1 or 2 short spears a foot or so from the long one to keep the bale from spinning.
/ moving large squares #7
regular round bale spear with a couple "anti-rotation" prongs moves them easily. Spear from the side of the bale, not end or top.
Thanks for the input. Finally found a bunch of good small squares. Got them moved just fine with a pair of gloves. Ha
2014 International WorkStar 7500 T/A Leach 2RIII 25Yd Rear Loader Garbage Truck (A64556)
2014 International...
12ft T/A Utility Trailer (A64557)
12ft T/A Utility...
2022 JOHN DEERE 17G EXCAVATOR (A63276)
2022 JOHN DEERE...
2000 Ingersoll Rand DD-24 Tandem Smooth Drum Vibratory Roller (A64553)
2000 Ingersoll...
2007 Mack CTP713 Wet Kit T/A Day Cab Truck Tractor (A64194)
2007 Mack CTP713...
LOOK! (A63111)
LOOK! (A63111)
