Moving bale rings with forks
   / Moving bale rings with forks #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
Has anyone figured a good attachment to lift round bale feeding rings with pallet forks? I've destroyed one ring by just putting the forks under the top bar and lifting.
   / Moving bale rings with forks #2
If you can, what we do is we tip the rings up onto the side and then pick them up in under. this does of course depend on how big the ring is and how well built it is
Thanks, Pro. I hadn't thought of that.
   / Moving bale rings with forks #4
we just carry it on a small loop of chain. They are a bit clumsy to move though if you don't hook em just right. To move it just a short distance tip it up on its side and roll it.
MH,
Thank you. I rolled them around for years with no ill effects. In an effort to stay out of the mud, I thought I could just run the forks into the bays and lift. This approach only bent the heavier ring a little. The ring made with thinner walled tubing just bit the dust a couple of days ago.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2025 Swict 78in Bucket Skid Steer Attachment (A51691)
2025 Swict 78in...
PAIR OF 7' HOOK ON TRAILER RAMPS (A51247)
PAIR OF 7' HOOK ON...
2004 TRAVIS 48' WALKING FLOOR REFUSE TRAILER (A53426)
2004 TRAVIS 48'...
2022 Kubota B2601 (A50123)
2022 Kubota B2601...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
