Moving and need to buy a new TLB next year.
   / Moving and need to buy a new TLB next year. #21
When you have a cab no problem with
branches when you clear your path so
you don't have the problem. Now if your
lazy and don't clear the path then look
out!!!!!!!!!!!! I have seen so many tractors
with cabs in the woods and they don't have
broken windows and the only time I have
seen a broken glass on a tractor is when
the door was left open and driver went fast
down the trail in the woods and came back
with the mangled door.
There is always somebody that says
(you don't want a cab in the woods)
maybe they shouldn't drive a tractor in the
woods because they just might get hit with
a branch????????????
willy
   / Moving and need to buy a new TLB next year. #22
willy
Yup I live in a forest with a cab tractor, cab excavator, and cab RTV. No issues here.
   / Moving and need to buy a new TLB next year. #23
Thick, untouched forest that I'm going to need to make some roads through. Moving trees and brush, a lot of firewood carrying. Grapple for moving trees and large rocks. Will need a box blade for the road work and a plow for snow when it comes. Digging a small basement as well as a sunken greenhouse and lots of trenching, burying water containers, etc.
If me I would get a local Dozer operator to rough in the road, clear the home site, dig the partial basement. The dozer operator can push trees over and you can saw the stump off he can stack the logs for later sawing into round and push the stumps off and into a pile for burning.
What you have outlined so far is a lot of back breaking work. The environment is also going to be harsh and unforgiving. Much different than Georgia. Shelter for the tractor and implements should be very high on your priority list.
Given the amount of snow annually in Maine I think looking at a tractor with a cab was a wise decision.
Tym builds a lot of tractor for other people. Any piece of equipment will break if abused and not properly taken care of and maintained. So don’t be afraid of the TYM. The key to longevity is take care of and do not abuse. And always remember as Clint Eastwood said in the movie “A man has to know his limitations.” In your case it will be you have to know the limitations of your tractor and not try to do with it jobs that require a Bull Dozer.
   / Moving and need to buy a new TLB next year. #24
SoGeorgia,
Interested in what part of Maine or town are you relocating to?
How much land area are you clearing for your home, then how long of a driveway/road?
Off Grid - do you plan to build the solar array first a ground mount?
Do you have surface water that is potable - stream/lake?
What's your plan - build a combo garage/barn/living area first then the main house? Or will you do a RV or trailer for temp quarters?
This sounds like an interesting project, and looking forward to your adventure!
   / Moving and need to buy a new TLB next year. #25
Echoing what tractorable said - you might really want a mini-excavator for initial site work instead. You can yank trees/stumps, cut ditches, scoop dirt, etc - much easier with a excavator in the 8,000-15,000 lb range than by abusing a 4000lb tractor.
If the the prices of mini and midi ex's in Maine are like they are around here, I would look for a full size used TLB with a cab and 4 wheel drive in the 12-20k lb range instead, extend a hoe would be a plus for digging at a distance as well.
Full size TLBs may not be the perfect tool for some jobs but am finding they can be a very good Jack of all master of none. A full size TLB will put a 474 to shame when push comes to shove or you need to lift something heavy or high for that matter. Digging bigger stumps will be much quicker as well.
You would lose the abilities of a 3 point though.
I am probably not in the majority but would be looking for 2 Used machines. the full size TLB and then additionally a used 30-50 hp 4 x 4 tractor with some included implements.
   / Moving and need to buy a new TLB next year. #26
I think for 26 acres you need a lot more than 20 HP and 2500# of tractor….don’t even get me started with grappling on that light of a tractor.
But let’s hear more about what you want it to do and how much time you want to spend doing it.
Agreed.
Buy a real full sized construction TLB. Use it for 5 years doing the tough jobs, then sell it for what you paid for it.
Then go buy a toy SCUT TLB to putz around the garden with. It will last longer that way.
SoGeorgia,
South of Calais, 26 acres on a lake with a stream running through it.
Probably will be clearing half an acre for the house. There will be several driveways/roads through the property. Probably .5 mile total.
The house or I should say cabin is going to be fairly small and I've designed everything around small electrical requirements. The lighting is 12 volt led, 12 volt fridge/freezer. Heat will be a wood stove and backup heat from a propane heater. Cooking and water heating is all propane. Outside of the 12 volt led lighting and fridge the only other electrical needs are my starlink router and computer/cell phone charging and a 12 volt water pump. I've already purchased the solar system, a wind turbine, battery banks and two backup generators. The wood stove, propane heater and water heater have already been purchased as well. I have not decided whether or not I will do a ground mount or roof mount for the solar panels. Will have to start with a ground mount of course while we are building the cabin and living in our RV.
We're super excited to sell this house and get out of debt and live off-grid. The 2 weeks we were there visiting we were fine with 200 watts of solar, water I pumped from our stream and couldn't have been any happier.
So if anyone in interested, and most probably won't be.. we made a video of our trip to our off-grid property.. if you like trees and fall leaves and don't mind suffering through a looooong drive off the main road to our gravel road and property give it a watch.
Disclaimers:
1) this is my first time ever editing a video and I don't run Windows or Mac so I had to find the best open-source video-editing software I could find and then try to figure out how to use it.
2) again, part of the video is a long drive.. there are some key points though that I title on the screen.. leaving the pavement for our gravel road, where our property starts, future driveway location,etc.
3) if you want to see what Maine looks like in the fall, give it a watch and maybe a like, and a comment.. if you get bored easily, don't bother watching 😄
Our first trip to our off-grid property in Maine.
Club Car Carryall Electric Utility Cart (A55853)
Club Car Carryall...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2012 Chevrolet Silverado 3500 HD Enclosed Knapheide Service Truck (A55973)
2012 Chevrolet...
2020 Chevrolet Tahoe SUV (A55973)
2020 Chevrolet...
Deere 325G (A57148)
Deere 325G (A57148)
Kubota M5-111 (A53317)
