Moving a storm shelter
   / Moving a storm shelter #1
cowpatty
Oklahoma
TYM 454; Ford LGT 14D
OK here it is guys. I have been given a 6'x8' precast storm shelter. The trick is i need to move it from where it is in the ground to my house. I have a Kubota b21 to do the digging and cleanup but other than calling companies that sell and install these things I am stumped on how to get it out of the hole it sits in to my hole I am about to dig. Any ideas??
   / Moving a storm shelter #2
Try to find out how much it weighs. I would try and lift it out of the whole with the back hoe. If you can't lift it out then I would dig a ramp and try to pull it up.
Those are my ideas so far.
   / Moving a storm shelter #3
Im assuming it is a concrete box, like a septic tank. If so, you are going to need a much bigget tractor to lift it.
   / Moving a storm shelter #4
call a company that puts these in then you do all the prep on both ends have them move it between they have all the gear and do it all the time if you break it trying to move it your out of luck
   / Moving a storm shelter #5
concrete weighs anywhere from 100-150 pounds per cubic foot. Figure out how thick the walls are and calculate how many Cu ft of concrete are in it an that will give you a range for how much it weighs. But I highly doubt you will have the lift capacity, reach or lift height to do it with a B.
I know for a fact my tractor wouldn't even wiggle this thing much less move it. It will sure dig the hole though. Just curious if anyone has heard of this or even tackled it and if so what equipment they used.
   / Moving a storm shelter #7
Beneath the cell towers in our area there is usually a concrete building set on a concrete slab. This to keep all the expensive stuff from getting damaged when ice falls off the towers. They came in on a semi and were set by a crane. Your B will be a digging tool only.
   / Moving a storm shelter #8
My best GUESS is this building could weigh close to 16,000, which you would need a 70,000 pound excavator to be able to handle this, like a Komatsu 300 series machine. If the building weighs more than that, you might need to bump up to a bigger excavator, depending on soil conditions, etc.
In my area, that class of excavator is oversized, requiring permitting to move. Just to move across town you are looking at $400 each way. So I assume three trips (shop to the building, to the new location and back to the shop). Plus another trailer to haul the building. Time it is dug, moved and reset, probably an all day affair @ 175/ hour. So I would guess you are at $3,000 plus the trailer to move the building, and guessing on the oversized permit costs.
   / Moving a storm shelter #9
Hire the septic tank folks to pull it, haul it and set it in your hole.
   / Moving a storm shelter #10
The Egyptians moved much larger and heavier pieces of stone with people power. :D
That doesn't help you at all, but it seemed a good moment to bring it up.:laughing:
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
2016 CATERPILLAR 249D SKID STEER (A52705)
2016 CATERPILLAR...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
