Move GC2360 snowblower from GC2300 to GC1725
   / Move GC2360 snowblower from GC2300 to GC1725 #1
loulblades
Butler County, PA
MF GC2300/GC1725
To All,
I recently re-tasked my 20 year old GC2300 and purchased a GC1725 and want to use my GC2360 snowblower on the new tractor.
From what I have seen, the 2360 fits all GC series tractors (basically the front hitch and drive shaft) but I am looking for an adapter to go from
the old GC2300 to the larger GC1725 hydraulic connectors for the front loader.
I notice the float rate is higher on the 1725 (6.9 gpm) vs 2300 (6.1 gpm) and am wondering if I will need a regulator of some sort,
but since the 2360 is supposed to fit all GCs maybe not.
So if anyone knows the part # of an adapter, I would appreciate it.
I will continue researching but thought I would consult the experts first.
Thanks in advance.
Lou
   / Move GC2360 snowblower from GC2300 to GC1725 #2
Can't help you on the rest of it, but for sure a higher AVAILABLE flow rate is not ever an issue. The hydraulic pressure needs to be about the same (and almost certainly is) but there is no such thing as too much available flow rate. No you do not need any regulator for that.
Thanks JWR,
Am currently thinking I will just have a couple hoses made at the local hydraulic joint. Just need to figure the size. I have tried to get into the AGCO parts site as guest the last couple days but was having issues.
Lou
2017 LEEBOY 8520 ASPHALT PAVER (A51242)
2017 LEEBOY 8520...
(4) HD 16' Corral Panels (A50515)
(4) HD 16' Corral...
Hutchinson 10" Transfer Auger (A50514)
Hutchinson 10"...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
VOLVO L45G RUBBER TIRE LOADER (A51242)
VOLVO L45G RUBBER...
2012 Freightliner M2 106 Ambulance (A50323)
2012 Freightliner...
