Move B hazard lights to inside ROPS
   / Move B hazard lights to inside ROPS #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
Has anyone done this. They are inside on the LX.
   / Move B hazard lights to inside ROPS #2
Yes, swap sides (right light to left inside etc.) the wires run down the rops legs and plug in to the harness. It is a simple job that takes about a half hour. It will go much quicker if you pull a thin rope through the rops when you pull the wires. You can then use it to pull the other wire back through when you install the "Swapped" light.
Good to know. Had to swap them on the JD like this, too. May be getting a B2301.
However, after seeing a couple videos and see how they are attached, I don't see how you could put them inside the ROPS. They're attached to an L shaped piece welded onto the ROPS. No such L shaped piece inside the ROPS.
Found out you can get new ones for $30. LOTS cheaper than the light assemblies on JD 1 and 2 series.
2017 John Deere 5090GN (A53317)
2017 John Deere...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
Club Car Utility Cart (A55853)
Club Car Utility...
