Movable Shooting Backstop.
   / Movable Shooting Backstop. #1
Deere Dude
Elite Member
Beaver Dam Wisconsin then to Hohenwald, TN
John Deere 3720
This is my target stand for shooting. The pic shows up small for some reason but is 2.5' wide and 6' high. The bullets blow through it and hit a hill or lawn in a wooded safe area. I have a wooded 75' foot hill on both sides of the lawn. One side has houses on top.
It works fine so far but I want to try something different and just want a couple ideas. I planned on cutting railroad ties in 3' chunks and stack them up to 6' high and bolt them onto one side of this stand. This way I can still move it around to get different view like next to the driveway of farther away from the house etc. This helps spotting for range but I can still shoot from a place easier to pick up the brass. No matter the location I will not have it even remotely toward a house.
I know for the first few hundred rounds in a relatively small area will be fine but what about when lead starts piling up. Do I need to worry about bullets bouncing off and coming back.
   / Movable Shooting Backstop. #2
What would work better is to get some of the large nylon totes bags and fill with sand. Then stack these for your backstop. Ties could cause ricochet when embedded bullets hit one another. Depending on rounds going down range, speeds could be 2700fps plus! Better to have earthen backstop that could be raked and scaped every so often.
   / Movable Shooting Backstop. #3
Just build a steel trap where the bullets are diverted straight down into some sand.?
   / Movable Shooting Backstop. #4
Traps are good. Building a swinging target may be easier. This is a .45 Colt 250 grain bullet that hit my swinging target and dropped to the ground.
   / Movable Shooting Backstop. #5
Maybe I missed it but what firearm(s) are you shooting? Big difference between a 9mm and a .300 Win Mag.
   / Movable Shooting Backstop. #6
I don't have pics handy but I built one that is about 4' tall X 8' wide. It's made with 2x6 framing so that the inside is hollow, 5.25" deep. Both sides are finished with 3/4" treated plywood. But, the front first has 1" rubber horse-stall matting attached to the frame, then the plywood. The interior of the frame is filled with sand.
The front plywood holds targets (stapled) and the rubber mat reseals the bullet hole after is passes thru. The sand has stopped almost everything I've thrown at it.
   / Movable Shooting Backstop. #7
My idea of a backstop is something you would feel safe putting your wife and kids behind when you shoot at it. Something that has no chance of passing whatever round you plan on shooting at it. Anything less, and you don't really have a backstop at all. It should have great side protection, too.
   / Movable Shooting Backstop. #8
I only shoot .22 here mostly, steel target plinking, my backstop is a big tree stump which I didn't bother digging out of the ground. I'm planning to reinforce it with more tree stumps which I got lying around, gonna make a "u" shape with them.
That sounds like a good idea.
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2021 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2021 FREIGHTLINER...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
