Mouse Wiring Damage
   / Mouse Wiring Damage #1
Mr Majestic
Michigan
1993 Ford 1920
Took my 1993 Ford 1920 dash apart to troubleshoot some display issues. Found major mouse damage to the wiring. Anyone been through this before and came up with a good fix? Can I buy the wiring from the dealer or are there companies out there that can rewire the dash panel?
Thanks in advance,
MM in Michigan
   / Mouse Wiring Damage #3
That was one hungry rodent! Two yeas ago, I also had a mouse build a nest on top of my NH 1920 gas tank and chewed through most of my dash wiring but I discovered it before he had chewed all of the wires. My tractor repair guy took the dashboard and the wiring harness pigtail to the bench and matched the wire insulation colors to repair the harness with quick connectors. Been working fine since. I attached some dryer sheets inside the tractor dash area, near the nesting spot to hopefully keep the rodents away. I don't remember the replacement price of the dashboard gauges and wiring but it must have been significantly higher than the repair.
Update: my New Holland dealer wanted $480 to replace the wiring harness and circuit board. I found a local small electronic repair shop that rewired everything (replaced a failed diode too) for $150 cash. I should be all set with the electronics...now on to the engine rebuild!
   / Mouse Wiring Damage #5
I tried to buy a car one time and had it sold to someone else after I had an agreement with the seller, the buyer told me that most of the wires on the hole car had mouse damage and he wished he had never gotten it. look around and make sure that is all the damage you have. Hope all the rest is good.
   / Mouse Wiring Damage #6
Many years ago - brand new Chrysler Concord. The little buggers cost me $875 for an entire new, dealer installed wiring harness. I found an acceptable temporary fix - a heavy row of moth balls, on the ground, from the front to the back of the car.
Permanent fix - barn cats, several of them. Right now my last cat went to either an owl or coyote for dinner. I'm living on borrowed time until I can replace with a couple new cats.
Darn cats get too brave and go out beyond the influence of the yard light, at night. They learn a permeant & lasting lesson - beyond the yard light is the realm of the owl & coyote.
   / Mouse Wiring Damage #7
Update - I checked with my vehicle insurance company today and they DO cover rodent damage to vehicles. Won't stop the damage but will pay for any repairs. AND BTW - still looking for a few barn cats.
2015 John Deere 8370R (A53317)
2015 John Deere...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A55853)
2014 Glasstream...
2003 INGERSOLL RAND SD-105DX DBL DRUM ROLLER (A52707)
2003 INGERSOLL...
