Mounting the mower deck LT 1550
   / Mounting the mower deck LT 1550 #1
Bobrm2
Cub Cadet Lt 1550
I've been try to re-mount the mower deck on my LT 1550 off and on all day, 1st I push and pull for a while, then I kick and cuss a little bit,,...just kidding. But I'm having problems getting the deck to sit back in the correct position, after installing a new 63.00 belt.
Now the back is up on it's pins, the deck is lowered all the way down, but it won't quite reach the front mount bar. Oh, the read pins, after a long tug are in the 2nd pin holes. Can someone tell this thich headed Irish man how to go about this task. Thanks
Bob
I was going about it, backwards. Needed to mount the deck to the front bar, with the belt off the forward pulley, then lift the back into place. Thank away.
BR
2019 Hefty 16' Landscape Trailer, VIN: 5NKBU1620KP011139, Tandem Axle, 48" High Steel Cage, GVWR: (A59076)
2019 Hefty 16'...
2025 ZJG ZJ-13 Mini Excavator (A56857)
2025 ZJG ZJ-13...
New/Unused IRGC40 Mini Golf Cart (A57453)
New/Unused IRGC40...
1652 (A58375)
1652 (A58375)
2015 UTILITY 48FT REEFER TRAILER (A59575)
2015 UTILITY 48FT...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
