mounting monitors in 4600 cab
   / mounting monitors in 4600 cab #1
Skyfish25
Panora, ia
MF 4610
Need to mount a monitor in the cab of my 4610. It a SM3000 planter monitor. Wanted to get some ideas before I start on it next week. I thought someone had mounted a baler monitor in theirs but can't seem to find with search. Pictures are helpful.
   / mounting monitors in 4600 cab #2
Get a RAM mount. Not cheap, but it will work and keep your monitor from falling.
Aaron Z
   / mounting monitors in 4600 cab #3
Look on the A and B and C pillars, there should be plugs you can remove to access the threads to screw in mounting bolts for your monitor mount. This will give you some idea what options you have. I don't like a monitor in my face (B pillar), so I use the A pillar mount point, also easier on your neck. Also I find C pillar mount point obstructs sight lines for the mower and rake and tedder (6 rotor).
2012 Ram 3500 Chassis Pickup Truck, VIN # 3C7WDTAL9CG134341 (A51572)
2012 Ram 3500...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A53472)
2000 Kenworth W900...
RHINO DB150 LOT NUMBER 76 (A53084)
RHINO DB150 LOT...
BROWN BDH-600 LOT NUMBER 174 (A53084)
BROWN BDH-600 LOT...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A53472)
2020 Westfield MKX...
1264 (A50490)
1264 (A50490)
