mounting monitors in 4600 cab
   / mounting monitors in 4600 cab #1
Skyfish25
Panora, ia
MF 4610
Need to mount a monitor in the cab of my 4610. It a SM3000 planter monitor. Wanted to get some ideas before I start on it next week. I thought someone had mounted a baler monitor in theirs but can't seem to find with search. Pictures are helpful.
   / mounting monitors in 4600 cab #2
Get a RAM mount. Not cheap, but it will work and keep your monitor from falling.
Aaron Z
   / mounting monitors in 4600 cab #3
Look on the A and B and C pillars, there should be plugs you can remove to access the threads to screw in mounting bolts for your monitor mount. This will give you some idea what options you have. I don't like a monitor in my face (B pillar), so I use the A pillar mount point, also easier on your neck. Also I find C pillar mount point obstructs sight lines for the mower and rake and tedder (6 rotor).
2012 JOHN DEERE 410K BACKHOE (A51406)
2012 JOHN DEERE...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
