Mounting Lights...Have Questions
/ Mounting Lights...Have Questions #1
jgbanshee
PA
JD 310SE, 325G, 35G, 4300, 5300, 5210, 445, 450 Crawler, CAT D3B, Ford 2N, 7000, 5000, 4000su, 3610, 445D, 345C, 340B, 1100
I have three 12V lights that I am mounting on my tractor canopy. I would like to supply power to them via 1 wire up ROP and then 3 separate wires. One to each light.
What is a clean way of splicing off the power supply to 3 different lights? Something like a terminal block or is there something else?
/ Mounting Lights...Have Questions #3
I just used a 4 way flat trailer connector.
/ Mounting Lights...Have Questions #4
For a "clean" transition you might also want to consider simply soldering the junction of wires and then using an inch or two of "adhesive lined heat shrink tubing" (3:1 shrink works well for this). The material is inexpensive. You will have a splice that is stronger, waterproof, and 100% reliable.
See here_ Adhesive Heat Shrink : BuyHeatShrink.com : Adhesive Polyolefin : Dual Wall heat shrink
You should be able to find it locally.
/ Mounting Lights...Have Questions #6
I'd go with a terminal block like Mike has suggested. I use the jumpers that straddle over the terminal block's insulating fences as they take up less space.
/ Mounting Lights...Have Questions #7
as much as I like terminal blocks.. I'd second the option of the solder and heat shrink, with a lil rtv in the joint before shrinking...
soundguy
/ Mounting Lights...Have Questions #8
I LOVE TO USE QUIK CLIP CONNECTORS YOU CAN GET WATER PROOF ONES A LITTLE MORE MONEY BUT WORTH IT.THE NICE THING ABOUT THIS IS YOU CAN UNHOOK LITES IF NEED BE AND RE CONNECT .REMEMBER I.M TALKING ABOUT INDUSTRIAL GOOD QUILITY CONNECTORS
/ Mounting Lights...Have Questions #9
Regarding sealing wires or connectors with RTV.
As "Soundguy" mentioned RTV is handy suff, and some would work fine.
But,
Many sealants are corrosive to wire and connectors. You can be sure the sealant is wire safe if it specifically states electronic grade or something like that. For example stuff found at MG Chemicals > Cleaners, duster, silicones, prototyping, epoxy, coatings, lubricants, thermal management and others are elec-grade.
Your home shop sealant (e.g. silicon) is almost certainly corrosive if it smells like vinegar.
I've wired a number of cop cars over the years and always soldered/heat shrink where ever I could. Never use crimp connectors (unless crimp/solder). Some push connectors are fine but use something like Permatexョ Dielectric Grease here. The same stuff you use on your trailer connector, breaker box...
For a perfectly sealed connections something like this 3:1 double wall heat shrink tubing is great. Adhesive Heat Shrink : BuyHeatShrink.com : Adhesive Polyolefin : Dual Wall heat shrink
The 3/16" diameter stuff would shrink to 1/16" and creates a hot glue seal. No need for further tape or sealants...
It's very reasonably price @ $2.25 for 4 feet, which should be good for about 30 splices.
It's real easy to use just slip about 1" of the tubing over your soldered wire(s) and apply an indirect flame using a butane lighter. The tubing will shrink snug and glue will ooze out the ends in about 10 seconds. It's best to heat from the center out. You can protect nearby wires, paint... from your lighter flame using Renolds Wrapョ.
*Not all heat shrink tubing is double wall and lined with adhesive. This type can be identified by its shinny interior surface. Also; some tubing shrinks at 2:1 but it's not as handy and the price difference is marginal for home users.
Sorry- probably boring you
/ Mounting Lights...Have Questions #10
can't imagine using non elec grade silicone 'caulk' for an electric purpose..
soundguy
/ Mounting Lights...Have Questions #11
soundguy
I can't either but, I think there are plenty of people who do not know there are different kinds!
/ Mounting Lights...Have Questions #12
there's a reaso why the small hand-squeeze tube costs about 2x as much as the long gun-type tube. :)
soundguy
/ Mounting Lights...Have Questions #13
I've had good luck with the liquid tape stuff. Just solder up the joint then paint on the liquid tape which I let dry a while and paint on another coat.
/ Mounting Lights...Have Questions #14
Just finished mounting a rear work light on my JD 2305. I soldered the connections and put heat shrink over them.
I re-installed the light because I just had a cab put on my tractor. The work lights were on for three years, installed the same way with no problems.
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
1974 Ohio Body Dry Van Trailer (A64047)
1974 Ohio Body Dry...
2014 Freightliner 114SD T/A Dump Truck (A61573)
2014 Freightliner...
Bad Boy Z-Turn Lawn Mower (A64047)
Bad Boy Z-Turn...
