Mounting a tire
/ Mounting a tire #21
I had to repair my front last year and posted a story about it here: Kama DIY Tire Repair
I do most everything myself and the experience I've gained is priceless. Yes, failures as well as success adds to experience. Just be careful and use common sense. I used what I had at camp and succeeded.
/ Mounting a tire #22
Most times I take them to a dealer. Try mounting the 4 ply Carlisle Super Lug 23X10.50-12 tires for fun. Talk about a pain. Did 1, took 2 hours to get it on. took it to the dealer and it took them an hour to do. One tough tire.
But on the other hand, the other night I had a flat on a Gravely riding sulky. By the time I got back to the house, it was loose on the rim. I was so mad, that I didn't want to take the rim off. Grabbed the top of the tire with the weight of the sukly pushing the rim downand the tire in the groove.. Pulled the topof the tire righ over the rim and off. Shocked. :eek: Decided to see if the new tire would go on the rim that easy. It did! :eek: :eek: No tools tire change and done in under 10 minutes.:D Tire is a 4.80/4.00-8.
Easiest ones to change are the Gravely 4.80/4.00-8, 16X6.50-8, 18x7.50-8 and 18X9.50-8 tires on the Gravely 6 bolt split rims. Install one rim section on tire. Install tube in rim section.Install other section lining up bolt holes. Install the 3 rim bolts. Inflate tube and the deflate. Inflate to about 5 PSI and install on tractor. Inflate to correct tire pressure. Done. Love those two section rims for ease of doing.
/ Mounting a tire #24
Iron Horse said:
Now those split rims will kill you . If you do'nt deflate the tyre on a forklift etc and remove the wheel nuts which also hold the rim together you will be lucky to survive the impact . I have an elderly friend who has been a mechanic all his life who should have known better . He removed an Aluminium boat trailer wheel that was held onto the hub with four wheel nuts . The remaining four bolts held the rim together aided by the four wheel nuts . He pumped the tyre up to full pressure while it was on the ground . The four bolts could not contain the pressure on their own . The rim exploded and showered him with shrapnel . When you see the words "deflate tyre before removing wheelnuts" heed the warning .
Ouch!! I've never had a tire/rim blow on me, but I act like it could when I work with em. Safety first.:eek:
/ Mounting a tire #25
I've fixed flats on both split rim and split ring truck tires, but not on any held together by wheel nuts. I think those would be very rare in this country. But any of them can be very dangerous. Several years ago, one of my brothers was working at Camping World and mounted a truck tire on a big motorhome wheel. It was a tubeless tire on a solid wheel; not split rim or split ring, but Camping World had just bought a new cage to put the tires/wheels in when inflating them so he put it in the cage. However, the cage was sitting against a wall and had not yet been anchored down to the floor. Well, it turned out to be a defective tire; supposed to run 100 psi and it exploded at 80 psi. The explosion drove cage and all away from the wall, knocking my brother backwards onto the concrete floor and he was taken to the hospital unconscious in an ambulance. Fortunately, he only suffered a mild concussion. And of course, that Camping World store didn't do anymore tire work until that cage was securely anchored to the floor.
/ Mounting a tire #28
I worked at a service station when I was in high school so I am more than passing familiar with removing and installing tires. A guy a year or two ahead of me worked at a competing station and had a tire blow up. It shot up to the ceiling of the service bay and bounced back hitting him in the head killing him instantly. I off roaded in Baja for several years where the availability of tire service was inversely proportional to the odds of needing it. I think it is good to know how to do it yourself but...
The local tire shop (less than two miles) will break down a tire patch it, remount it and inflate it or take one off and install a new one, either way, for $10. I don't have a tire machine so even if I know how to do it with or without a machine or by inflating with an explosive mixture, I just pay $10 and do something else for a while and pick it up later. Flats used to be $5 five years ago but inflation you know (monetary not pneumatic.)
Pat
/ Mounting a tire #29
Yep, the one man shop where I used to get my annual motor vehicle State Safety Inspections done down in the country, until five and a half years ago, charged $5 for fixing a flat and it didn't make any difference whether you just took him the tire and wheel, or drove into the shop for him to take it off the vehicle and put it back on. It also was the same price whether he put a plug in it or broke it down and patched the inside; your choice.
/ Mounting a tire #30
I just did two skinny cement mixer tires. My friend bought them brand new 6 years ago, and the tire shop took out the tubes, and disposed of them. The tires would go flat overnight, Anyways it sat for years flat, and dry rotted the one small spot on the ground.
He gave me tubes to put in ,which I did,(i hadn't seen the rot ). and upon inflating one had a small but growing bulge. before I could pull the stem. kaboom it tore open. ruining a good new tube.
it only had about 20 lbs , but quite an explosion.
reminds me when i got my new tractor a few years ago. i was loading wood in the bucket, and could hear some noise, the sidewall was like a basketball , I headed and dumped the wood.
it kept growing until BANG it exploded.(only about 90 hours on the tractor).I took it back to the dealer and they replaced it but moaned.
about a week late rim watching TV and I hear whet sound like a gunshot.
A day later I find tire number two on the other side flat. I returned that one and they really groaned.Must have been a bad batch. either way what a noise.
/ Mounting a tire #31
One of our power line contractors hit a live high voltage line with a cherry picker . The truck was found to be allright and was sent on another job . All the tyres blew within a 100 yards . The steel belts in the tyres that where closest to the ground were disintergrated by the power going to earth .
/ Mounting a tire #32
Pat
Good point.. know how to do it.. whether or not you pay someone else to do it.
Funny that i will sometimes mount my own tractor tires.. yet take my car to the mechanic for brakes and tires ( I done em both before.. takes too much time now! )
soundguy
/ Mounting a tire #33
I found that when using the pry levers etc to stretch the last bead onto the tire, that it's much much easier to let the oppsite bead go on down between the rims as far as it will. I almost destroyed the rear tires till I figured that out.
As far as doing it myself, and I mean by my self, what with the thirty miles to a town and waiting or wasteing a trip cause I have to leave it,plus what ever they charge. I have plenty of time to learn how to do it. Retired.
/ Mounting a tire #34
I think that's what Iron Horse called the "well" in post #7 of this thread. And of course, with some wheels it makes a difference as to which side of the rim you start with. That well is sometimes farther in from the rim on one side than the other and you'd like to work from the side that has the well closest to the rim.
/ Mounting a tire #36
Egon, way back there 50-52 years ago when I was doing tire repairs, I'd never heard of a tire machine. We did have a little manual device for breaking the bead on ordinary car and pickup tires, but for trucks and tractors, we had a sledge hammer that was, in fact, a hammer on one side and much like a very very blunt chisel on the other side. It took a little practice initially, but you soon learned to swing the big sucker so that broad chisel blade hit the rubber right at the rim and slipped in between the rubber of the tire and steel of the rim (there was no such thing as aluminum or alloy wheels). And you just worked your way around the rim until the bead broke loose, then you turned the wheel over and did the other side. And yes, I did split rim and split ring wheels when we'd never heard of cages. Of course we had heard of people being killed by those things, so when I put one together, initially I'd put just enough air to straighten the tube without the valve core, then let that air out so the tube could relax and be straight in the tire. Then install the valve core, apply air a little at a time, and tap on the rim all the way around to be sure that split rim or ring was properly seated. We'd do that a half dozen times before getting up to the operating pressure. But then we wised up a bit and would raise the car lift, put the truck tire under there and let the lift down almost onto the tire. And I was lucky enough to never have one explode or give me any trouble.
Of course, the last one of that type I had to work on was in July, 1972, in Canada, enroute to Alaska, when twice I had to work on one of the tires/wheels on my 1971 3/4 ton Chevy pickup which still had bias ply tube type tires and split ring wheels.
/ Mounting a tire #38
Bird , i remember those old 20" cross ply truck tyres well . The rust band and tyre beads would be so rusted on i used to remove the lock ring and then carefully pump the tyre up until the bead would be forced off the rim . Then you had to turn it over and put the wheel on a dummy rim that was a little smaller than the rim and bash away with the short sledge hammer and chisel . Sometimes i would resort to using the bulldozer blade to force the second bead off . After a lot of swearing the bead would let go . I was so happy to see the tubeless 22.5" truck tyre come along , they were a pleasure to change compared to the 20".
/ Mounting a tire #39
On some of our farm wagons we used to put the tyre in a fire and heat it up before pounding it over the rim!:D :D :D
/ Mounting a tire #40
I think this is a point that could use some emphasis in the Gempler's article.
I can change bicycle and motorcycle tires up to about 4.60 x 18 entirely by hand.
I mean ENTIRELY by HAND, that is WITHOUT tire irons or anything used as a tire iron.
The "trick" to it is to manipulate the beads into the well of the rim and work the "slack" to the opposite side, very little force is needed.
I learned this as a youth (without much tool savvy), tire irons would BITE me, typically in the face as I lay stretched across a wheel and took a hand off of one to get a third one started. They would just fly up and whack me, which must have done some good because I figured out a better way.
By leaving the rim on the tractor and using the sequence of positions described in the Gemplers article you can drop the beads into the well at the top of the rim.
Gravity can be your FRIEND for once.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2015 Kawasaki Prairie 400 ATV (A64557)
2015 Kawasaki...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
(9) STAMPED INTERNATIONAL FRONT WEIGHTS (A64278)
(9) STAMPED...
USA Flag Metal Decorative Sign (A64557)
USA Flag Metal...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
