Front-End Loader Mounting a Rhino PHD to a FEL
   / Mounting a Rhino PHD to a FEL
bjcsc said:
Looks good. 2 questions, though: 1) Why did you choose the high flow vs. the low flow? Your max flow at your remote is 8.3gpm. The low flow is rated for 5-12gpm and the high for 10-25. and 2) If the mount bangs around a bit and monkeys up the threads on the "set bolts", how will you get it off?
I was going to get the low flow and the dealer talked me out of doing it, he said it will just turn slower no loss of power. Also I may put it on my Case 580 TLB. So far it works ok on the L3130, I'll find out how it does on heavy clay soon.
If I screw up the bolts I'll just take a cut off wheel on a grinder and cut them off, then back them out. I usually turn the last couple threads off in the lathe so if it mushrooms the end no big deal, just didn't have time. Also I'm going to use chains and binders to hold it on, like Rhino does. I was going to drill a couple holes to see how I wanted to do the chain mount, glad I did I changed my mind three times so far LOL.
   / Mounting a Rhino PHD to a FEL #13
Bill Barrett said:
psj12, yes I'm using just the remote hydraulic, and I bought the larger GPM PHD, works good in standard ground. I let everyone know how it does in heavy clay soon. The way we made the mount if the L3130 can't handle it I can put it on 580 Case TLB.
Ductape, I have two pieces of 5" x 5" x 1/2" x 6" long angle welded to back of angle thats on the cutting edge, it's tapped with 4 -1/2" bolts that hooks just behind the edge. Also I think I'm going to chain to the bucket, but so far it holds well.
so where are the controls for the phd? maybe im just missing something
You sit in the seat, to your right and back. It's the control for the power beyond, push and hold one way, forward, push the other way, reverse, let go it stops. I think it's much safer than power take off PHD.
   / Mounting a Rhino PHD to a FEL #16
Am I to understand correctly that the Rhino hydraulic PHD cost $400? Or was that just the mounting bracket? I would be really interested in buying one. I have a Danused PTO digger now. But the hydraulic unit looks like it would be just the thing to mount on my Komatsu trackhoe.
Scott
Scott
No that was the bucket bracket and hose kit. I think you can get a high flow 10 to 15 GPM with one auger and bucket bracket/ hose kit for 1895.00
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
2013 Nissan Sentra Sedan (A53424)
2013 Nissan Sentra...
Native American Wooden Statue (A55853)
Native American...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
Toro 880 Procore (A55758)
Toro 880 Procore...
MUSTANG MTL320 SKID STEER (A52707)
MUSTANG MTL320...
