Front-End Loader Mounting a Rhino PHD to a FEL
   / Mounting a Rhino PHD to a FEL #1
Bill Barrett
Platinum Member
midwest
Kubota L3130, Satoh G650, Case 580, Case 446
Here are couple pics of us mounting a hydraulic PHD to a FEL.
   / Mounting a Rhino PHD to a FEL #2
Are you using standard tractor hydraulics to power this or do you use a PTO pump? I like the idea of hydraulics due to the ability to reverse the auger should it hang in a rock or large root. Please let us know how it works.
   / Mounting a Rhino PHD to a FEL #3
I may not be seeing something, but what holds it onto the bucket? Is it clamped onto the cutting edge?
Nice set up !
psj12, yes I'm using just the remote hydraulic, and I bought the larger GPM PHD, works good in standard ground. I let everyone know how it does in heavy clay soon. The way we made the mount if the L3130 can't handle it I can put it on 580 Case TLB.
Ductape, I have two pieces of 5" x 5" x 1/2" x 6" long angle welded to back of angle thats on the cutting edge, it's tapped with 4 -1/2" bolts that hooks just behind the edge. Also I think I'm going to chain to the bucket, but so far it holds well.
   / Mounting a Rhino PHD to a FEL #5
I checked woodsequipment.com and didn't see the hydo PHD listed. Did you use the same model they build the skidsteer units with? Could you point me to the unit you're using? I would think the GPM output of a tractor would'nt be enough to turn the unit at rated speed.
Thanks alot for the pics! I'd like to do something similiar.
   / Mounting a Rhino PHD to a FEL #7
It appears to come in high and low volume hyd. motors. I actually like the mount shown on the Rhino site where it is on the side of the bucket.
psj12, I thought about that, it was 400.00 and some change for that and 12' hoses. Looked like to me it would twist the FEL, and I didn't want to drill all my buckets plus I needed more the 12' of hose. The way I made mine it will just slide on anything over 59", give plenty of support and I have alot less then $400 subtracting time that is.:D
Ductape, here is how I have it mounted now. Also after I use it some I'm going to add chains, I was going to do it like the company did on there mount but glad I didn't because I'm up to plan C already.:D
   / Mounting a Rhino PHD to a FEL #10
Looks good. 2 questions, though: 1) Why did you choose the high flow vs. the low flow? Your max flow at your remote is 8.3gpm. The low flow is rated for 5-12gpm and the high for 10-25. and 2) If the mount bangs around a bit and monkeys up the threads on the "set bolts", how will you get it off?
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
2007 International 4300 Box Truck (A47384)
2007 International...
UNUSED FUTURE QUICK ATTACH PLATE GRABBER (A51244)
UNUSED FUTURE...
Satoh S-650G Tractor (AS IS) (A50774)
Satoh S-650G...
UNUSED FUTURE PAIR OF MINI RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
2015 Hyundai Sonata Hybrid Sedan (A50324)
2015 Hyundai...
