Mounting a bale monitor
   / Mounting a bale monitor #1
farmer2009
Elite Member
Western KY
Multiple
Trying to help a friend put his bale monitor in his new tractor. It's a Vermeer monitor and a LS 7040 cabbed tractor. He wants to put it on the right hand door rail. He came up with an idea of welding a custom bracket to some black pipe that's the same outside diameter as the hand rail. Then clamping it to the hand rail with hydraulic hose frame clamps. But we are having trouble finding the clamps. OD of pipe is 1.25 inches. Does anybody know where to get them? Does anybody have a better idea?
   / Mounting a bale monitor #2
might try some u bolts
   / Mounting a bale monitor #3
These are roll cage brackets he could weld this on instead of that other pipe.
   / Mounting a bale monitor #4
Why not just buy a monitor bracket? Most tractors come with at least one or they are an option.
   / Mounting a bale monitor #6
Double split shaft collars weld one half to the new bracket then you can clamp the bracket to the hand rail.
I've tried to get him to call the LS or the Vermeer dealer and see what they had to no avail. He's determined to build it himself. Cheaper. Found something similar to what foreman Texas posted. Actually used his search title. He likes the idea. I'll try to keep this posted.
   / Mounting a bale monitor #8
Do a google search for 1.25" or 1 1/4" "tube clamp" you should find all types of ideas
   / Mounting a bale monitor #9
There might be some ideas on how to make one here.
https://www.google.com/search?q=Ver...0ahUKEwi2mPXP7fzKAhVQ92MKHbnUBJMQsAQIRA&dpr=1
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
John Deere 24in Digging Tooth Bucket Excavator Attachment (A55973)
John Deere 24in...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
16 BLADE DISC HARROW (A52708)
16 BLADE DISC...
20 X 20 CAR PORT (A58216)
20 X 20 CAR PORT...
