Mounting a 42 Snowthrower to a 335
   / Mounting a 42 Snowthrower to a 335 #1
shany1
Manhattan, IL
John Deere 335, John Deere Z 665
Hi all, I ran across a like new 42 snow thrower Serial# 03252 this past weekend it was previously mounted to a GT 235 with a manual deck lift and missing the mounting rod for the spout controls. Here are the questions I currently have (anything else anyone can think of would be appreciated):
1) I am guessing I need a different lift kit anyone know the Part # for the lift kit?
2) I have the controls with the metal bracket that mounts to the mounting rod for the spout control. However, I do not have the mount rod and if there is anything else that is required to mount the rod to the tractor? I went to the dealer and they unfortunately were not much help and offered me several part numbers.
Thanks for any suggestions in advance.
   / Mounting a 42 Snowthrower to a 335 #2
Go to jdparts.com (free registration) and put the model no. 42 in the search. It will take you to a list, where you will scroll down and find the 42. Look under "sectional" in the index, and you will see the parts for the 335.
Should be able to see the schematics of the parts as well.
Thanks for the help. I have a follow up question, I have entered the model number "42" and tried the serial number but so far to no avail any further suggestion?
Never mind been there, I figured it out thank you again
   / Mounting a 42 Snowthrower to a 335 #5
:thumbsup:
2012 Seal Rite SR 1000, Tandem Axel Trailer  (A52384)
2012 Seal Rite SR...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A53472)
Kubota BX2680...
Modine Shop Heater (A51573)
Modine Shop Heater...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
PENDING SELLER CONFIRMATIONS (A53426)
PENDING SELLER...
