mountig blower on front of tractore
   / mountig blower on front of tractore #1
jim andrew
callander
belarus 5150
looking for some does & donts mounting on a 5150 belarus jim
   / mountig blower on front of tractore #2
Jim not familiar with a 5150 Belarus do you have any pictures of your tractor? Exactly what are you looking to do?
i want to mount a 7 foot blower on the front of my 50 hp belarus jim
   / mountig blower on front of tractore #4
Stanley the Belarus 5150 appears to be a sturdy, classic-looking large-frame 4x4 50 HP ag tractor.
Jim, in order to have a FEL-mounted blower you will need a "harness". It's a PTO extension that runs underneath the frame from the rear PTO to the front of the tractor. You will find those at your blower dealership. In your case it may have to be custom-fitted.
i am looking for information on where i could find a set of gear boxes to front mount i have the frame work for the underside of the tractor jim or maybe go with a hydraulick drive
   / mountig blower on front of tractore #6
What is the hydraulic capacity of your tractor (gallons per minute and quantity)? Most of the info I find online is in Russian so it's difficult to get the figures.
   / mountig blower on front of tractore #7
Size matters...... But you don't have to run your snow blower at full bore capacity....most operators don't. Slice off a section at a time. Your tractor feel will tell you if your overloading your 50 HP.
   / mountig blower on front of tractore #8
You don't want to dork around with a pto drive from the back to front. Some of those European tractors could be optioned with a front three point hitch and front pto.
Only workable rig is a hydraulic driver two stage blower mounted on a front end loader. And a massive pto driven hydraulic pump.
Lot cheaper to just use a rear mounted blower.
   / mountig blower on front of tractore #9
Jim, google MK Martin Front Mount Kit.
They make a kit to mount rear snow blowers to the front using the mid PTO.
i dont have a mid pto i must run off rear pto jim
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
Cruise Car Electric Utility Cart (A51691)
Cruise Car...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
CAT Skid Steer (A50322)
CAT Skid Steer...
