Mounted sprayer to tractor 3PT
   / Mounted sprayer to tractor 3PT #1
buffdan
Buffalo Ny
Kubota B3030
My very clever neighbor and I rigged this up for temporary sprayer use. I took the top off my middle buster and he attached unistrut to it . Very solid with adjustable height.
Neighbor is working his property to install food plot and lawn. When project is done I will take apart and put the middle buster back together.
Needed to get this done so rigged this up. Might explore a permanent solution for ATV
The middle buster is a A & B Eagle, very robust unit, weighs 138#
   / Mounted sprayer to tractor 3PT #2
What size is the tank? Where is the pump and switch mounted?
I've been planning something very similar
20 gallon, switch temporary hook up to battery, pump mounted on underside of tank
   / Mounted sprayer to tractor 3PT #4
When that tank is filled, there is going to be a fair amount of leverage working on it. Bumpy ground will give it a workout.
3pt carryalls can usually be found around here used for less than $200. Fairly easy to set down on the ground and take off the tractor when not in use. It helps if they are easily slid around on the ground when it comes to reconnecting them to the tractor.
Didnt feel like spending $200 for temporary project. Taking it slow when spraying.
   / Mounted sprayer to tractor 3PT #6
I bought a cheap 3 pt hitch attachment for a 2" receiver. I see one now on eBay for $41. I figured on building a rack for the tank with a 2" tube to go into the receiver.
I also go a 26 gal Northern equipment spray tank and pump. Good to see somebody else doing this. I would like to be able to turn the sprayer on/off from the operators seat.
   / Mounted sprayer to tractor 3PT #7
For a temporary project, looks like a lot of careful work went into it.
   / Mounted sprayer to tractor 3PT #8
Uni-strut is a very versatile and handy item to have floating around.
My neighbor had extra unistrut and fittings that his company was throwing out (thats another subject on how companies are wasteful) It was his idea to use unistrut, I was going to use plywood. :) I havent used that middle buster in years, I was going to try to mount sprayer to it, but that was a no-go. I was going to buy 3PT hitch/receiver, but decided why not use the top part of the middle buster. It is really quite solid. his tractor is certainly large enough to handle the 190# hanging out the back
2017 Skytrak 10054 10,000lb 4x4 Rough Terrain Telehandler (A56857)
2017 Skytrak 10054...
2137 (A58376)
2137 (A58376)
2018 CATERPILLAR GRAPPLE RAKE (A58374)
2018 CATERPILLAR...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
LOT: Assorted Pry Bars & Punches (A59076)
LOT: Assorted Pry...
25 DUAL AXLE GOOSENECK TRAILER (A58216)
25 DUAL AXLE...
