Mount M8071 weights on front of B7100HST tractor?
   / Mount M8071 weights on front of B7100HST tractor? #1
travelrider73
Palmetto, FL
Kubota B7100HST
Can anyone recommend a bracket that I might be able to retrofit onto a B7100HST that would accept the M8071 weights?
I have 1000# of these M8071 weights and so I'd rather use two or three of these rather than buy something else.
If I could find an M-Series bracket and take some measurements off of it and have a look at it, I suspect I could fabricate something.
Any ideas?
Not trying to spend a fortune because I'm going to upgrade the tractor in a few months hopefully. Just trying to do something to hold me over.
   / Mount M8071 weights on front of B7100HST tractor? #2
Search for threads or posts that 4shorts did on adding weights to the front of a small Kubota. He did it right and fabbed his own bracket. The man is a genius with Kubota mods.
Unless you are going to use those M8071 weights in the future you could sell them for maybe $85 each and buy what you wanted? You could also make a simple flat bracket, weld on stub 1" round stock and slide on barbell weights. I've done it.
Pics of my M bracket are in other threads here and the pattern is the same for most anything from an M6800 on up.
   / Mount M8071 weights on front of B7100HST tractor? #3
Any ideas?
Can't answer your question, but you might want to consider buying the proper weights for your 7100 from North States. They will be less expensive than Kubota weights and if your dealer accumulates orders for 1,000 Lbs. or more, shipping to the dealer is free.
North States does not sell retail so you will need to purchase through a dealer.
SDT
2004 KENWORTH DIGGER TRUCK (A50854)
2004 KENWORTH...
2012 MACK PINNACLE (A50854)
2012 MACK PINNACLE...
2013 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2013 MACK GU813...
2017 F-550 Bucket Truck (A51039)
2017 F-550 Bucket...
2015 WESTERN STAR 4900 SF (GLIDER) (A50854)
2015 WESTERN STAR...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
