Mount M8071 weights on front of B7100HST tractor?
   / Mount M8071 weights on front of B7100HST tractor? #1
travelrider73
Member
Palmetto, FL
Kubota B7100HST
Can anyone recommend a bracket that I might be able to retrofit onto a B7100HST that would accept the M8071 weights?
I have 1000# of these M8071 weights and so I'd rather use two or three of these rather than buy something else.
If I could find an M-Series bracket and take some measurements off of it and have a look at it, I suspect I could fabricate something.
Any ideas?
Not trying to spend a fortune because I'm going to upgrade the tractor in a few months hopefully. Just trying to do something to hold me over.
   / Mount M8071 weights on front of B7100HST tractor? #2
Search for threads or posts that 4shorts did on adding weights to the front of a small Kubota. He did it right and fabbed his own bracket. The man is a genius with Kubota mods.
Unless you are going to use those M8071 weights in the future you could sell them for maybe $85 each and buy what you wanted? You could also make a simple flat bracket, weld on stub 1" round stock and slide on barbell weights. I've done it.
Pics of my M bracket are in other threads here and the pattern is the same for most anything from an M6800 on up.
   / Mount M8071 weights on front of B7100HST tractor? #3
Any ideas?
Can't answer your question, but you might want to consider buying the proper weights for your 7100 from North States. They will be less expensive than Kubota weights and if your dealer accumulates orders for 1,000 Lbs. or more, shipping to the dealer is free.
North States does not sell retail so you will need to purchase through a dealer.
SDT
405 (A52706)
405 (A52706)
2002 Kenworth T300 TMA Attenuator Truck (A55973)
2002 Kenworth T300...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2025 Full Body Zero Gravity Massage Recliner Chair (new/Unused) with High Fidelity Bluetooth Surr... (A59225)
2025 Full Body...
8'x14' METAL TRUCK BED (A58374)
8'x14' METAL TRUCK...
2008 Ford F-250 Service Truck (A56858)
2008 Ford F-250...
