Mott flail mower
   / Mott flail mower #1
CattleM2
John Deere 5065e
I recently purchased an old Mott flail mower, model M255 according to the tag. The guy I bought it from didn’t know much about it. I replaced the drive belt and greased it but noticed a small round opening on the drive shaft cover between the gear box and the belt pulley. It’s obviously a machined opening, I’m just not sure it’s a vent hole or an access opening that I need to fabricate a cover for the opening. It appears to have some grease inside it. Any suggestions appreciated. Thanks
   / Mott flail mower
Also where is a good place to buy replacement parts like bearings for the Mott flail mowers? I haven’t had much luck just searching online yet.
   / Mott flail mower #5
They got bought out by Alamo, so I’d speak to a dealer.
If you can get numbers off a ball or tapered roller bearing, usually those can be cross referenced easily.
   / Mott flail mower #6
   / Mott flail mower
   / Mott flail mower
2012 Peterbilt 337 IMT 6025 14,000lb 5 Ton Crane Mechanics Truck (A50323)
2012 Peterbilt 337...
3001 (A51691)
3001 (A51691)
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
2007 Ford Ranger Ext. Cab Pickup Truck (A50323)
2007 Ford Ranger...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
