Motorized rotary Bush hog
   / Motorized rotary Bush hog #1
Blackfoot
North Central Wa.
Cub Farmall,Farmall A,Ford 8N,MF35
I was wondering if a guy could mount a motor on a pto driven bushhog and make it into a pull behind cutter. Has anyone tried this if so I would be interested in how they did it. Reason I was wondering is I have two small pull tractors that I could use more efficiently. BF
   / Motorized rotary Bush hog #2
Sure why not? However most air cooled small engines run around 3600 rpm and the pto is 540 rpm so you would have to reduce the speed if you are using the gearbox. In the process think about a tractor mounted kill switch just in case something happens and you need to shut it down. I personally never tried it but the amish/mennonites' do it plenty.
   / Motorized rotary Bush hog #3
I like the idea but am trying to put the cutter on my fel so i can cut under the trees all with thorns this would put the cutter10 or 12 ft in front of me. I am trying to cut brush that has been growing for 40 years you can,t walk on most of it. I need lots of help...............
   / Motorized rotary Bush hog #4
You can also put a hydraulic motor on the bushhog & run hoses to a tractor hydraulic system, motor driven pump, or pto pump. MikeD74T
   / Motorized rotary Bush hog #5
How big of a brushhog and how big of a motor (I assume you mean gas engine?) do you have to start with? If it's an electric or hydraulic motor, please correct me.
   / Motorized rotary Bush hog #6
Really? Wow...I learn something new every day. I thought that gas and electric devices were verbotten for the most part...for the Amish anyway.
   / Motorized rotary Bush hog #7
Travis:
I put a Bush Hog Squealer 48" mower on my Kubota L4330 FEL and drive it with a PTO hydraulic pump. It works pretty good in heavy brush like you seem to have. I also put stump grinder teeth (with replaceable carbide inserts) on the underside of the blades so that it cuts practically level with the ground, and it cuts very clean because the carbide stays sharp (until you hit a rock). There should be some pictures that I posted a few months back, and I have made several "improvements" since then. If you are interested send me a private e-mail and I will get you some updated pictures.
   / Motorized rotary Bush hog #8
This sounds like what I need. What HP tractor , will my pump put out enough for this. I will take photoes next time I'm in Castroville I,m new at this and don,t know how to send e-mail. Thanks you can e me at travistpot@aol.com.
   / Motorized rotary Bush hog #9
Travis, if you click on a users name a menu will offer the option to send a private message to that member. When you receive a private message a pop up will let you know when you sign on. You can also retrieve messages directly below where it says Welcome back, Travis Potter, when you sign on.
MarkV
   / Motorized rotary Bush hog #10
Blackfoot,
Swisher and bush hog already make them...
Swisher Mower & Machine Co.: Products: Trail Mowers
Travis,
What you need is one of these...
They mow in places where you can't drive and just eat up what is in the way. Start at the top of a tree and just let it eat thru to the bottom, or just take the limbs off if that is what you want. Reach is about 25 feet in each direction, including up. As much as that tractor weighs, the mower can pick up the front wheels by just reaching out a little too far towards the rear. Keeps you on your toes, no question about it.
Now, about hydraulic decks...
I bought this thing to make what you guys are thinking about, but came across the 7710 with the Turner mower, so i really don't need it.Anyone interested?
24' Free Standing Panel with Swing Gate (A50515)
24' Free Standing...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52748)
2022 Down2Earth...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
Brent 420 Auger Wagon (A50514)
Brent 420 Auger...
Wolverine Fork Extensions (A50515)
Wolverine Fork...
New Idea Tandem Manure Spreader (A50774)
New Idea Tandem...
