motorized FROPS
   / motorized FROPS #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
Has anyone motorized their frops yet?Adding 12 v linear screw motor and some spring latches should fold it up and down with a dash mounted switch.Would solve the in and out of the garage problem.I'll work on this. Ideas anyone?
   / motorized FROPS #2
How would it solve the problem? You still need to remember to fold the FROPS down or the motor is a moot point.
   / motorized FROPS
It would solve the problem of getting on and off the tractor for us lazy folks.Yes you would have to remember to flip the switch.
   / motorized FROPS #4
Won't you still have to get off the tractor to pull the ROPS pins? I wouldn't rely strictly on a linear screw motor to support it in case of a rollover. Besides, if your like me I need the extra exercise getting on and off the tractor.
   / motorized FROPS
George, as the linear motor(s) raise the top part of the bar two heavy duty spring loaded clamps or claws for lack of a better name would engage two new 1/2 in pins mounted on the lower portion of the bar firmly locking it in place.Kind of like the metal clips we used to hang in our garages on a wooden board on the wall to put broom and rake handles in,but much more heavy duty.They would latch with the bar raising and release when lowering.Look ma, no hands!.HMMM.
Actually to make it even simpler you could install two 12 v plungers, like the electric deadbolts you see advertised flush mounted in the upper half of the frops with the beveled side toward the front of the tractor with corresponding holes in the fixed section of the bar.As the top section raises the spring loaded "door latches" compress riding on the fixed portion of the bar until they both arrive at their respective holes and then decompress just like a door latch at home.Linear motors have internal limit switches which will kick in when the holes are met.You are now securely locked in the up position.To unlock and lower, have the 12v lock cylinders wired to the down side of the switch for the linear motor(s) retracting them.They will not be powered in the up position relying on the spring pressure to engage them at the holes.
I've got WAY too much time on my hands!.
   / motorized FROPS #7
What's a FROPS?
   / motorized FROPS #9
bones1,
Well, I guess you're the guinea pig to start the project. Post lots of pictures showing components and procedure, please. It will be an interesting thread to follow.
   / motorized FROPS
I will. Also an electric fence opener will do and it comes with remotes and logic controlled electric locks.Not sure which way to go yet.......more ideas.
I think if engineered correctly this might have a market.
There is a wire sensor you bury underground near the garage door that detects the tractor at a spot you set and the rops is lowered automatically for entry.These units have electronics that can also operate your garage door on approach as well.Just think of how an electric gate works on approach and it all makes sense,to me anyway.
This is all very doable,and i'll build it sometime.
I know 3RRL can do it.
Woods Brushbull 720 3 pt Mower (A50514)
Woods Brushbull...
Towable Orchard Sprayer (A51691)
Towable Orchard...
Paladin Tag Quick Coupler (A50774)
Paladin Tag Quick...
2014 John Deere 700K LGP Dozer (RIDE AND DRIVE) (A50774)
2014 John Deere...
2015 International DuraStar 4300 Johnston VT651 Street Sweeper Truck (A50323)
2015 International...
DMI 3200 Side Dress Bar (A50514)
DMI 3200 Side...
