motorcycle battery for tiller
   / motorcycle battery for tiller #1
rald
East TN
Any reason I shouldn't use a motorcycle battery on large tiller with PTO? The last couple 'mower' replacement batteries haven't lasted even with trickle charging over the winter. I've read that the best gauge of battery quality is the warranty. I can't find a mower-type battery with more than a 3-mo warranty, but the motorcycle batteries of similar footprint and CCA offer much longer warranties. I know they cost more, but I wondering if there's something else I might be missing before trying one. I currently have a bolt-on connector. Changing the terminal connectors should be straight-forward. It just seems I am doing something wrong - it shouldn't be that hard to find a battery that lasts more than a couple seasons. Thanks for any input.
Ralph
   / motorcycle battery for tiller #2
I would try one. I would get 2-4 years off a battery on a motorcycle.
   / motorcycle battery for tiller #3
Most bikes are a vibration prone environment, so even a basic motorcycle battery should be a step up.
A tiller seems to be a very high vibration environment - in that respect I'd be inclined to go with a good quality sealed (ie. not a traditional "wet" flooded lead acid) battery. A decently designed AGM type battery (meaning like Optima) is inherently more immune to vibration than a flooded lead acid type. Any well stocked motorcycle dealer should have sealed batteries in stock.
You have been using an offboard trickle charger, so I'm assuming that defective charging is not the problem.
Rgds, D.
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
TRUCK BED PORTABLE FUEL TANK (A51248)
TRUCK BED PORTABLE...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51691)
2013 International...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A53473)
2020 Westfield MKX...
