Motor on brush hog leaking
   / Motor on brush hog leaking #1
RegL
Platinum Member
Northwestern CT
PT 1430
Looks like it's leaking where the end cap on top meets the side caseing. There are six bolts on the top. I don't know if they just hold the top piece on or if they are thru bolts and if I take them out the whole motor falls apart. It would be nice to plug the leak if it's an easy fix, but if there's a chance of putting the mower out of commission, I'll wait untill the season is over.
   / Motor on brush hog leaking #2
Just a thought, have you tried tightening the bolts? That might do it.
Caution - I had a motor leak on my stump grinder and almost ran the reservoir dry. At 2500 PSI you can loose fluid real fast. CHECK YOUR HYDRAULIC FLUID OFTEN. I took that motor apart and there is an O ring under the top. I tried to rebuild it myself and damaged it while using too big a socket to push out the shaft seal. If all you have is a leak on the top, you can probably order a seal kit and replace just the O-ring. Call Terry at PT and see what he says.
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2024 Bison Tek Skid Loader BT360 (A52384)
2024 Bison Tek...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53472)
2011 New Holland...
UNUSED FUTURE FT-X1200J STAND ON MUD BUGGY (A51247)
UNUSED FUTURE...
