Motor oil
   / Motor oil #1
Jnasystems
Waukesha Co, WI
1986 Ford/NH 1520, 1950 Allis Chalmers WD, 2001 NH EC35 (track hoe)
Last week I got my first antique tractor - an 1950Allis Chalmers WD. In reading the owners manual I discovered the oil is supposed to be 10w in the winter and 20w in the summer. It seems to me that a good 10w30 should be good all year, but being new to this I figured I would ask. What do you use? What about synthetic?
   / Motor oil #2
Synthetic would be great if it doesn't leak around the main seals. The seals in new vehicles are made to hold in synthetics.
The older machines specified single weight oils because the multi-weight oils were not as good back then. I would try the multi-weight oil and keep a close eye on the level to see if it is using too much.
   / Motor oil #3
if in the north 10w30 should be ok, if it holds good pressure.
I'd avoid synthetic unless it was rebuilt in modern times.
this assumes it is a gasser too :)
soundguy
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53473)
2020 New Holland...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
2006 iDrive...
Mahindra MPOWER 85P 4WD Tractor (A53117)
Mahindra MPOWER...
