Motor lock
/ Motor lock #1
girls4
judsonia,ar.
4ooo ford ,new holland TC33d
Cousin ran his mothers TC33d into pond nose first and motor shut down. He drained all water and pulled inj. but can only turn engine back and forth a few inches. Suppose its got a bent rod. Never worked on this one. Will the oil pan come off without pulling engine and is there anything in valve train that may cause this. New to forum and thanks.
/ Motor lock #2
HI. Welcome.
Are you sure all the cylinders are empty It could have bent a rod but usually they break on a impact like water in the cylinder. Drain all fluids if that has not already been done (oil, gas, trans, hyd.
The crankcase could be full of water preventing the piston from traveling down. Replace all filters (air, oil, trans, hyd.).
/ Motor lock
Thanks for reply. They had already drained fluid and I had them to pull injectors in case there was water on top of pistons(it would push out). Engine was only part in water but figured I would pull head and check for rod bent one at a time.
2021 Ram 5500 4x4 Crew Cab Service Truck (A64556)
2021 Ram 5500 4x4...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
HARDEE 1084 - 7' ROTARY MOWER (A64278)
HARDEE 1084 - 7'...
2011 UD Thermoplastic Truck (A64194)
2011 UD...
JOHN DEERE 541 QUICK ATTACH SELF LEVELING LOADER (A64278)
JOHN DEERE 541...
16ft. T/A Utility Trailer (A64557)
16ft. T/A Utility...
