motor help
   / motor help #1
tlbuser
Veteran Member
lower part of Md.
JD310, ASV RC-100
I need to purchase a 11-12 cu.in. A frame with a 7/8 x 13 tooth shaft. Anyone know where to find the right number codes for the different manufacturers?
   / motor help #2
I looked at Surplus Hydraulics and didn't see any. If you order new from the manufacture, you will pay big bucks, but you can specify the shaft desired. The other option is to purchase an adapter, that will convert the 7/8 13 T, to a more common shaft. However if the receiver is something like a hydraulic winch and has 7/8 13 splined input, then you are limited. Search Ebay, Surplus Hydraulics, and Baileynet.com.
Can you tell us how it is being used?
1995 INGERSOLL-RAND SD40F PADFOOT ROLLER (A51246)
1995...
UNUSED INDUSTRIAS AMERICA L6 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
