Mostly scrap built (but still awesome) land plane
   / Mostly scrap built (but still awesome) land plane #1
NS Gearhead
Nova Scotia, Canada
Deere X350
This will only be put together once the snow's gone, but I've been gathering parts and recently started doing some fab work, so couldn't help but start a thread. :)
It's going to be 4'X4', 2X8 C channel runners, 4" pipe crossmembers (filled with sand), Zamboni blade adjustable from 0-1", manual adjustable with two trailer jack mounted casters, operator's seat (for operating the jacks)
Here's the sketch I used to explain to my neighbor (Colin) how it's going to work LOL
2" up, 6" long
I bent that piece with my mini maul most of the way and held it with an 1/8" gap with the bench vice while I welded it. Capped the end with some 1/4"
I don't think I'll bother tapering the back edge...
Pipes notched to fit over the channel
That's it for now, but the plan is to have everthing ready for final assembly in the spring. I'm thinking it's going to weigh around 300lbs, and Colin will make it 480lbs.
   / Mostly scrap built (but still awesome) land plane #2
Good start. I built this one day for shaving off gopher mounds.
Cheap and cheerful but works well for the purpose.
Bought the other C channel and 4" angle iron. So I'm in the $120 range so far;
$46 channel
$20ish angle (I'll have to look at the slip again)
$50 two jacks
Cut to length and mocked up
   / Mostly scrap built (but still awesome) land plane #6
I'm watchin'. I have fun following all your projects, but I haven't responded much. I appreciate you sharing, and I'll bet a lot of others do too, but are just kind of silently watching you work without saying much...
Fair enough, and good to know! I'll carry on then.
   / Mostly scrap built (but still awesome) land plane #8
We are looking too, I just don't have anything constructive to add to the conversation.. Carry on.
   / Mostly scrap built (but still awesome) land plane #9
I am watching this and the side by side. :thumbsup:
Liked your trailer build also. :)
   / Mostly scrap built (but still awesome) land plane #10
I'm loving it so far. Especially your welder cart!!!! B.
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
Reserved (A53117)
Reserved (A53117)
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
2015 Ford Transit 250 Cargo Van (A51692)
2015 Ford Transit...
