Most to Least Used PT Implements???
   / Most to Least Used PT Implements??? #11
1 4n1 Bucket
2 stump grinder
3 brush mower
4 mini hoe
5 snow plow
6 tiller
7 rake
SnowRidge said:
Rather than weld one on, you could do what I did. I took a 1 1/4 inch receiver, cut off the excess length, and drilled a hole in it for the PT's pin. It fits between the two pin flanges.
What I'm thinking of is welding a receiver hitch onto one of my buckets -- likely the HD rock bucket unless I cut it up and make something else out of it...
I'd like the receiver on the bucket for two reasons:
1. To prevent using a QA plate just for a front trailer hitch for moving my trailers around, and
2. Put it on the bucket so I can use a cradle-mounted hydraulic winch at some point (when it makes it to the top of "Toys Most Wanted" list) and have weight of the load pull the bucket into to the ground to provide more resistance. I'd like to angle the bucket, and let the leading edge and teeth help serve as an anchor into the ground, rather than the load on the winch dragging the PT all over the place.
I was ready to do that to the HD rock bucket, until I got to thinking about cutting it into pieces and making two things out of it, instead. (I don't use it now that I have a grapple bucket with teeth and a LM bucket for hauling stuff).
1. I've thought of cutting each end off the HD rock bucket at about the QA plate, then welding new ends on it, perhaps at an angle to see if that would work as a narrow "grubbing bucket" for making shallow ditches, perhaps digging up shrubs to transplant, etc.
2. Then, taking the ends that I've cut off, welding them together with some reinforcement at the seam, and making a wide bucket for the minihoe so I could use it more like a GradeAll, to clean out ditches and smooth and shape the roadbanks on my driveway, landscape between trees and shrubs, etc. I'd like a wide bucket, 18" to 24" -- not to dig holes with, but to "hoe" with like a manual hoe... set it down, put pressure on it and pull...
We'll see! Meanwhile I have a spare QA plate and a step-bumper receiver sitting in my garage, waiting to see what gets welded where...
   / Most to Least Used PT Implements??? #13
Dear Ken,
I can't wait to see the Grade-All like rotational attachment. Photos please!!
All the best,
Peter
   / Most to Least Used PT Implements??? #14
I agree with having a hitch receiver front and rear. I find having one on both ends very, very useful.
I added one to my power dibble, which is nothing more than a QA plate with the business end of a planting bar welded to the bottom. I welded the receiver to the face of the QA plate, and I just rotate the QA to the horizontal position to fold the dibble up out of the way and position the receiver toward the front. It works fine.
Attached are a couple of shots of my removable rear receiver in use.
   / Most to Least Used PT Implements??? #15
-finish mower
-LM bucket
-grapple bucket
-brush mower
-mini-hoe
-forks
-snow blade...have used some for grading as well
It seems like we go in spurts....sometimes the grapple gets used hard for several weeks...if we're dropping tree's, then maybe a few hard weeks on the brush mower. The finish mower is used 2 hours a week, the LM bucket is used weekly as well, especially during the mulching season.
   / Most to Least Used PT Implements??? #16
1. Auger
2. Mower
3. Forks
4. Rock Bucket
5. Rotor Tiller
6. Plow
7. Rake (Still haven't found something it is good for.)
   / Most to Least Used PT Implements??? #17
During Nice Weather:
1. 4 in 1 Bucket
2. Mini-Hoe
3. Blade
During Not-So-Nice Weather:
1. Blade
2. 4 in 1 Bucket (REALLY Deep Snow)
Mini-Hoe not used at all during the winter.
Obviously, I need more attachments; this is a pretty lame list!
Mark H.
   / Most to Least Used PT Implements??? #18
most to least in 300+ hours:
1. 4n1 bucket with teeth >250 hrs
2. Stump grinder 25 hrs
3. rake 8 hrs
4. 60" mower 6 hrs
5. minihoe 5 hrs
6. snow blade < 3hrs
7. dump trailer < 3 hrs
8. boom pole < 1hr
9. forks < 1 hr
   / Most to Least Used PT Implements??? #19
IN ORDER (some what) FROM MOST TO LEAST.
1. WITH THE PT AT ALL TIMES
-ROP {canapé©€ (Six lights and switches)
-Fire ext.
-Cigarette lighter 12 volt Power sockets
-Drank holder slides into wood splitter control mount
-Tool box
-Slow moving vehicle sign
-Rear view mirror, magnetic mount
-Strobe caution light magnetic mount
-12 volt DC Fan:
-Ball hitch on back
2. Quick plate receiver hitch
3. 28" side mower
4. 48 finish mower
5. Bucket 40 cu. Ft
6. Bucket 10 cu. ft.
7. Mini Hoe 9 bucket
8. 48 brush mower
9. Pallet fork
10. Pond rake 20 ft long folding
11. TRAILER
12. 6 ft. boom pole with hook extension
13. 48 box blade
14. Wood splitter
15. Hole Digger, 9", 12", auger
16. Stump Grinder
17. Ripper
18. Grapple Bucket 5 cu. ft. With Rock Teeth
19. Scrub 7 ft made from train rails
Wish list or Project to be made in order of wants
1. Bale spear
2. Trencher 4 and 6 teeth
3. Device for holding lifting 2 each 55 gal. Drums
4. Tiller 45" to 48" wide
5. 3 foot plow
6. Leaf vac and trailer
   / Most to Least Used PT Implements??? #20
-ROP {canap驀 (Six lights and switches)
-Fire ext.
-Tool box
-12 volt DC Fan:
-Ball hitch on back
3. 28" side mower
4. 48 finish mower
5. Bucket 40 cu. Ft
8. 48 brush mower
9. Pallet fork
11. TRAILER
13. 48 box blade
14. Wood splitter
16. Stump Grinder
17. Ripper
1. Bale spear
5. 3 foot plow
I think you forgot your sunglasses. .:cool: :D
2014 Evans 48' Drop Deck Trailer (A56469)
2014 Evans 48'...
Wooden Rocking Chair (A55853)
Wooden Rocking...
Pallet of Misc Jacks (A56469)
Pallet of Misc...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2013 Dodge Charger Sedan (A55853)
2013 Dodge Charger...
