Front-End Loader Most powerful third party fel brand?
   / Most powerful third party fel brand?
The more typical reason is a less costly bottom line for the tractor/loader package. After all, the number one reason to buy/sell an aftermarket loader is price. Features and specs normally are distant second and thirds in whatever order. Aftermarket manufacturers have to price under the OEM's and if they can beat their specs, so much the better. If the package isn't price competitive, it doesn't matter how pretty it looks sitting on the dealer's lot.
So is the only reason to buy a third party loader cost savings? or are there third party fels out there that are a step up in strength and power vs oem? if so, i'd like to know where potential buyers should look.
Theo
   / Most powerful third party fel brand? #12
The factory FEL's will most often be the neatest installation with the closest fitment etc. The aftermarket is one size fits many brands and there are tradeoffs.
The listed mfg's are all good.
One thing about fels. The old time 50's & 60's tractors had some spindly front axles and most of them could hoist 2000# without blinking. They often had issues over time, but still...
jb
I think its a given that the tractor manufacturers are in the best position to supply the best looking, best fitting, most compatible loaders for their machines - but are they the strongest and most powerful too? i suppose in some cases yes and some cases no. so maybe my impression is wrong and there are no hard and fast rules in the tractor fel world. some third party loaders might be better but they might also be on those machines simply because they are cheaper. maybe there is no one third party brand that stands out as a generally superior choice. not the answer i had expected but an answer just the same. thanks.
Theo
   / Most powerful third party fel brand? #14
I have a Koyker 160 on 28 Hp Jinma. I just recently loaded 3 pieces of steel I beams for a friend to take to the recycle place. The 2 pieces weighed in at 7,080# total. I was able to pick up 2 pieces and drive but the third piece was probably 15% heavier so I just picked it up and had him back the trailer under it. Both him and myself were impressed. I have also picked up the front end of a Dodge 2500 van to get it off a rock when the phone guy drove over it while fixing my service.
By the way, they were paying $165 a ton for scrap steel of that grade so it was a good trip.
Chris
   / Most powerful third party fel brand? #15
Having owned a Jinma/w Koyker 160 before my Kubota L3400/w L463 loader I can say there is no doubt the Koyker 160 is a well built and powerful implement. It also exceeds the capability of the tractor (front axle, transmission) to handle the weight and forces that can become very costly in repairs. The manufacturers are more inclined to match a machine to implements whereas third party vendors will give you specs and let you do the math. The bottom line is most of us at one time or another push our machines to the limit and then some. In the case of my Jinma on more then one occasion I spent days and dollars working on what I should have been riding on! The weight you picked up with the Koyker is impressive. I have been there and done and know all too well that just because I can do it doesn't mean it wouldn't be prudent to do one at a time.
   / Most powerful third party fel brand? #16
Chris
Chris, I flat out do not believe you on that story. There is no way that a Koyker 160, rated at 1500 pounds lift, is going to pick up and carry 7080 pounds. It is even less probable that it could pick up one that is over 8000 pounds. Quickly checking Koyker web site shows the largest loader they make for a 145-275 HP tractor would not be able to lift over 6000 pounds.
I also don't believe that a 3000 pound 28 hp tractor could pick up 7000 or 8000 pounds. It would require a counter weight in the 5000 pound range to keep the rear tires on the ground. Since the 3pt capacity of the Jinma 284 is 876 pounds, well that's a bit shy of what would be needed....
I also checked the weight per foot of I-beams. There are only a few that are over 100 pounds per linear foot. The heaviest I saw was 112 pounds per foot, making your 15% heavier than 7080 pound beam over 70 feet long. By the way, those are bridge girders 10" wide and 18" tall and VERY thick.
jb
Chris
Thanks for the input on koyker. a guy near me gets a lot more for his scrap steel. i have no idea how he does it. must be telling a blind buyer that it is gold or something.
Theo
Well, let me relate a little of the story behind the story. one of my small circle of friends bought a used skidsteer loader a while back instead of a loader for his new (to him) tractor. seems he can do a lot more with that skidsteer than others of us can do with our tractor fels. it does beg an interesting question. should my next tractor (which will not be a deere) be purchased with an fel? or for the same money plus maybe a little more should i buy a used skidsteer like my friend did? and hence the followup question re how to get the absolute strongest loader for a given tractor instead of going the oem loader route or used skidsteer route.
Theo
jb
I think he meant one piece at a time.
Theo
   / Most powerful third party fel brand? #20
Buhler Allied builds a very heavyweight frontloader.
If the added weight trades off in extra strength vs. a Swedish built Quicke.... i dont think so.
Ratchet Straps (A55852)
Ratchet Straps...
2017 Ford Fusion Sedan (A55853)
2017 Ford Fusion...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
American Flag Style Rooster Lawn Art (A55853)
American Flag...
2016 Club Car Carryall 710 Electric Utility Cart (A55853)
2016 Club Car...
2019 Dodge Journey Crossroad SUV (A53424)
2019 Dodge Journey...
