most liquid in a tank you can haul on trailer to truck before needing hazard
   / most liquid in a tank you can haul on trailer to truck before needing hazard #1
captjack
Eastern Shore,MD
jd 5400
I have a 100 gal diesel tank for my farm i use in my truck. I have a buddy that got a 200 gal tank he wants to use to bring aviation fuel to the farm for his helo. Talking with on of my buddies he was saying a local farmer went and got a 275 gal tote of def fluid and was brining it back to his farm and the DOT got him and wrote him up. I can't find anything online about what the max amount of fluid you can haul without needed and endorsement. Thoughts ??
   / most liquid in a tank you can haul on trailer to truck before needing hazard #2
I don't think that the 275 gallon plastic tote meets hazmat transportatio regs.
   / most liquid in a tank you can haul on trailer to truck before needing hazard #3
... a local farmer went and got a 275 gal tote of def fluid and was brining it back to his farm and the DOT got him and wrote him up.
From Kubota:
https://www.kubotausa.com/docs/default-source/safety-data-sheets/product-name/kubota-def.pdf
SECTION 2. HAZARDS IDENTIFICATION
GHS Classification
This material is not considered hazardous under the OSHA Hazard Communication Standard (HazCom 2012).
GHS label elements
Other hazards
None known.
Bruce
   / most liquid in a tank you can haul on trailer to truck before needing hazard #4
IBC Totes (plastic in metal cage) are usually 300, but if the product was truly 275 gallons then that is ~2200 pounds of liquid. Was he cited for lack of a placard? Hazmat placards are required if transporting a hazardous material in a bulk vessel holding more than 119 gallons. Yes, I know that DEF is not haz-mat. I would suspect he was cited for improperly securing a load and/or overweight (without knowing the model of the truck)
   / most liquid in a tank you can haul on trailer to truck before needing hazard #5
And the law is different between "residential" use and "ag" use. If I'm hauling diesel on an ag licensed trailer with an ag licensed truck, I can haul a lot more fuel than without the ag license, in Texas anyway.
   / most liquid in a tank you can haul on trailer to truck before needing hazard #6
I sure hope your buddy is aware of the issues of storing aviation fuel to prevent contamination.
Having tractor, or automobile fuel storage issues is insignificant.
Having issues with home storage of aviation fuel can be deadly,..... as in crash!
Flying over to the local FBO to fill up, is usually a much better idea.
   / most liquid in a tank you can haul on trailer to truck before needing hazard #7
120 gal is the limit in California.
   / most liquid in a tank you can haul on trailer to truck before needing hazard #8
IBC totes are usually 275 gallons. 330 gallon aren't quite as common but still plentiful. Intermediate bulk container - Wikipedia
The magic number for hasmat is some non-round number just over 100 gallons, probably that 119 mark. Makes the funky size at or just shy of that limit for some transfer tanks you see make more sense.
   / most liquid in a tank you can haul on trailer to truck before needing hazard #9
There can be local codes as well. In MA, aux transfer tanks over 30 (?) gallons have to be permitted by the local fire department and inspected annually. They are also limited to 100 gallons I believe. And the any transfer tanks may be limits on certain routes (ie transfer tanks are not allowed in the tunnels in Boston).
   / most liquid in a tank you can haul on trailer to truck before needing hazard #10
THIS is why you tarp things.....stops a lot of nosy eyeballs.
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
40' CONTAINER (A51248)
2017 CATERPILLAR 323FL EXCAVATOR (A51246)
2017 CATERPILLAR...
2022 JOHN DEERE 6140M LOT NUMBER 264 (A53084)
2022 JOHN DEERE...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
