Most cost effective way to divert water
   / Most cost effective way to divert water #41
Umm....I saw the picts several days ago.
Now I no longer see the picts.
   / Most cost effective way to divert water #42
I would do the ditching I wanted and I would NOT contact anyone,
if contacted you might find those areas are now deemed wetlands
and not to be drained as you would be upsetting the apple cart of feel goods.
   / Most cost effective way to divert water #43
I see pics on the previous page. Page 2 that is.
I see airbiscuit's pic and video on p2. Nothing else.
Wonder what is up?
Someone take them down?
   / Most cost effective way to divert water #45
I’m guessing OP took them down. Maybe all the talk about wetland designation was concerning so he left - and took the pictures.
MoKelly
i did remove the pics i don’t like having pics on the web to sit forever. I ended up getting my answers. So i do appreciate everyone’s help in this thread.
I’ll be just digging trenches like normal and and probably laying a pipe under about a 10ft section so i can cross.
   / Most cost effective way to divert water #47
You're the man!
   / Most cost effective way to divert water #48
I assume you are no where near central ohio?
I asked earlier where abouts you were at to see if you are close enough I might be able to help
   / Most cost effective way to divert water #49
I live in an area where the soil and land is very level and very low. Low as in, we are very near sea levels, in fact in some areas, they are below sea level. I am not an expert, but having lived in the area all my life, I have seen a little of what goes on. To drain land, the old method was to lay clay pipes. These pipes were I guess a foot long, and most about 4 or so inches wide. A special spade called a `gauge` was used to dig a trench by hand, and a `fall` or slight angle was given in the trench so ending in a `dyke` at the ending of the field. The `gauge` was a spade that was the width of the clay pipe, plus a bit, but the blade was a semi circle, like a rain gutter, but made of steel. Years ago the young men, my dad was one of them, would lay these pipes and were paid per the amount they laid. The pipes in the `top` of the field would be at least the depth of a plough, and simply recovered with the soil dug out. The pipes were simply laid end to end and the water crept through the gap/join. Many of these pipes have been down many years and still give good service. Today things have moved on, and today a machine is used that has a very large turning wheel with buckets on. This digs the trench and immediately behind the wheel, a continuous plastic pipe is fed into the trench. This pipe comes in various sizes and has small holes all over it. I have stood and watched both of these pipe outlets as they discharge into the dykes, or creek or river or what ever we all call them, and after a rain, the flow is fast and clean, so little soil is eroding.
Hey yes sorry i meant to reply. I certainly appreciate the offer but correct i am not near there.
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A55787)
BrushFox XHD72...
2019 INTERNATIONAL RH613 SINGLE AXLE DAY CAB (A56129)
2019 INTERNATIONAL...
2011 FORD F-450 (A52472)
2011 FORD F-450...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
golf cart (A55787)
golf cart (A55787)
2017 Ford F-650 Mason Dump Truck (A55788)
2017 Ford F-650...
