</font><font color="blue" class="small">( Yes, that is why I said AKA subframe...
The Kubota manual says "sub frame required" somewhere in it...and what they are calling a subframe is two brackets that are about 2' long, that replace shorter brackets on the side of the tractor. These things really do not fit the form of a real subbrame...but maybe with a stretch of the imagination...
)</font>
When I purchased my BL4690B backhoe from the dealer the deal I cut had the 'hoe shipped directly to me crated and I did the assembly & installation myself. There was nothing like what you are describing included with the 'hoe - hence my interest.
The only thing that came with it, as far as attaching parts, were the HD reinforced top link bracket and hardened pins, which replaced the standard issue items already on the tractor. Of course, it included a HD mast to connect the 'hoe to the top link of the tractor. Other than that the only other thing that even approaches what you are talking is the 3PH lift limter but I don't think that is what you are referring to.
</font><font color="blue" class="small">( If you look under the tractor there should be a bracket on each side that extends from the rear end to the loader frame. I can take a picture if it would help. These brackets are gray on mine and roughly 3/8 thick by about 4" high and maybe 30" long. What came off was about the same height and thickness, but maybe 12" long. I only know this because I was given the brackets that came off... )</font>
Since I did the assembly and installation myself I can pretty much say with absolute certainty that there isn't anything like this on mine - didn't come with it - unless it came with the FEL or MMM which were already installed when I got the tractor from the dealer.
It could be that it is an additional part number specific to whatever model tractor that it is being installed on (which would make complete sense)
Yes, I'd love it if you could post a pic - and perhaps post the part number if you have it handy.
