More Weekend MOWING Tragedy
   / More Weekend MOWING Tragedy #22
It's bad to be sitting on the top exterior of a big heavy object without any ROPS or shelter when it starts to roll. But it'd probably be much worse to be TIED there by a seatbelt. Maybe there's no practical opportunity to execute a strategic leap to safety, but, even so, getting thrown off probably improves your chances. Worst case, getting thrown might put you where the seat belt would have held you anyway.
   / More Weekend MOWING Tragedy #23
ROPS up and seatbelt on always. Tractors and mowers. The ZD1211 weights over 1600 pounds. Not something easily lifted if it goes over. Also wearing the seatbelt makes for a smoother ride.
   / More Weekend MOWING Tragedy #24
Yesterday I had a couple of guys here to do some cleanup and path clearing. There was a some what large 40 ft maple that had died along the one path, so we cut it; sure enough it pivoted slightly and hung up although it was cut clean through. No problem... I had my forks on the MX and raised them as high as I could and gave the tree a push; it swung over like a pendulum with the trunk going away from me and the top coming at me. I swear it happened in slow motion; I left the forks up and slid down in the seat and turned sideways so I wouldn't get squished. The tree settled on the rops and I didn't even get a scratch. God did me a solid yesterday...
   / More Weekend MOWING Tragedy #25
Mowing fields with rough spots and a 10-foot rotary cutter behind... doesn't take too much imagination to think what would happen if a bump popped me out of the seat... then a 5-foot tire holds me down and the cutter makes sure I won't have an open casket funeral. I'm getting better at ALWAYS wearing my belt with the ROPS up.
... and I've been told to never push on a dead old tree with my bucket. Those logs at the top are more solid than the trunk.
   / More Weekend MOWING Tragedy #26
Again, I'm fortunate. Relatively flat ground and only one type of tree. I've learned, after 40 years, how to safely fall a gigantic pine. I've had two kickbacks but I'm always far away when the "action" happens.
The accident - just really sad. It DOES look like a brand new mower.
(4) FORD 255/65-17 TIRES W/ 6 LUG RIMS (A58374)
(4) FORD 255/65-17...
2019 International HX620 T/A Wet Kit Day Cab Truck Tractor (A55973)
2019 International...
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A56858)
2012 Mack CXU613...
202482 (A54757)
202482 (A54757)
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
