More tranney problems with a GR 2100
/ More tranney problems with a GR 2100 #1
csr0831
Gentlemen
I know the subject of GR2100痴 and their weak Hydros has been beat to death, but I have one more question that I hope someone will be able to shed some light on. I have owned mine for about three years and it has only 73 hours on it., All maintainance has been performed as directed in the owners manual. This past summer I was trying to drag some old concrete blocks up from behind my bulkhead and it couldn稚 do it. The tractor was on grass and my question is; even thought it could not move the blocks, with the engine at WOT and the hydro pedal to the floor, should the wheels have spun? If I moved the steering wheel back and forth a bit the front ones would slip a little, but not the rears. Is the transmission really that weak, or is there a problem. I致e read about the adjustments others have performed because of slow reverse (mine is also slow and I have had problems backing up hill with it) and I intend to try adjusting mine too, but I haven稚 as yet. Thank you gentlemen, any and all help is appreciated!
Chris
/ More tranney problems with a GR 2100 #2
Chris
I have a BX2230 and I have bogged my before where the hydro would not move the wheels and it didn't spin. That was with a lot of traction and a load as I pushed into a pile of dirt. Normally, the wheels will spins if I'm in low gear. Not as much in high gear however.
I don't know if the same will apply to the GR, but I have a neighbor with one and he will lay hole shot patches in the grass if not careful. Very nice machine, just a bit pricey for what it is.
International 37 Square Baler (A65640)
International 37...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
Pole / Log Dolly (A62613)
Pole / Log Dolly...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
2014 International 4300 Single Axle Dump Truck (A62613)
2014 International...
Case SV280B (A62177)
