More torque for my Power trac?
   / More torque for my Power trac? #141
Do you guys not have parts manuals for VSP pumps. If you do, it will indicate whether you have relief valves.
As far as I can tell there are no Sauer Danfoss parts manuals available anywhere on the web. I have scoured it looking for one. I can't even find a mention of one--for any of their pumps.
I don't see how they could not publish parts manuals, so I am assuming they are only available to their register dealers, wholesalers, and OEMs.
I don't know about the other brands of tram pumps used in the Power Tracs.
   / More torque for my Power trac? #142
I have already call Danfoss technical dept, and they referred me to the distributors. I believe that if you ask nice at the parts desk, they will supply you with a parts list.
I had the parts guy at PT email me a breakdown of my pump awhile back. They might oblige you also. PT should automatically supply owners and parts manual, with an option to buy the factory service manual if there is one.
   / More torque for my Power trac? #143
I have discovered that Sauer-Danfoss has a repair manual for the series 15 pumps. Apparently, their service manual really isn't a service manual. :mad:
The repair manual appears to incorporate the parts manual. Although the repair manual exists as a PDF, it is not available on line. The PDF is almost 15 MB, so it should be a pretty good sized document. It used to be on the Toro web site, since several of the Toro service manuals incorporate it with reference links in their PDFs. However, it has since been pulled from the Toro web site.
I'm beginning to think Sauer-Danfoss is a company to be avoided. They appear to be deliberately limiting end user customer access to critical maintenance documents. :mad:
   / More torque for my Power trac? #144
The documents things to be systemic with PT.. Vendors don't give them, PT doesn't. I did get a nice manual with my Deutz, though. Almost car-ish in its design.
Hey Stray, I would not hold my breath on an emailed response. Seems they have the technology, they just don't know how to use it.
Phone call is the only way to go.
I have gotten this far guys. as soon as Terry replys i will post it.
Craig,
I have forwarded your message to Terry in Service - he will be getting
back with you soon.
Have a great day!
Kristie Asbury
   / More torque for my Power trac? #146
OK, I have found an exploded parts diagram of what appears to be my tram pump in a manual covering the Toro Sand Pro & Infield Pro 3040/5040 line. It shows relief valves mounted in the rear housing. They are not discrete valves, but a series of components that use the housing bores as valve bodies. They are topped by hex caps screws.
Based on what I see in the diagram, I am not going to pull those caps off. I am not in a position to risk the downtime if something goes wrong.
The manual also lists the specs for the pump:
Maximum Pump Displacement 0.913 in3/rev (15.0 cm3/rev)
Maximum Pump Flow Rate (98% efficiency @ 3400 RPM) 13.2 GPM (50.0 LPM)
Charge Pump Gerotor Pump in Hydrostat
Charge Pump Displacement 0.33 in3/rev (5.4 cm3/rev)
Charge Pump Flow Rate (60% efficiency @ 3400 RPM) 2.9 GPM (11.0 LPM)
Charge Relief Setting 135 PSI (9.3 bar)
Implement Relief Setting 1100 PSI (75.9 bar)
Traction Relief Setting 3200 PSI (220.7 bar) in Forward Direction
If those same traction reliefs are in the PT-425 pumps, they may be too high to work in that application. They do not appear to be adjustable.
In the meantime, I have spent way too much time on this. It's Spring, the season to trot out the power equipment and try to break it. ;)
   / More torque for my Power trac? #147
Well now, who wants to be the first to look and see if there are relief valves installed. According to the diagram, they are on the rear of the pump, about a third from the top. If you look on the the pages in the PDF , pages 26 of 32, you will see. The question is do all 422's and/or 425's have this pump?
   / More torque for my Power trac? #148
Only the 425s as far as I know.
The pump is rotated on at least some of the 425s. Top is a relative term in this case.
   / More torque for my Power trac? #149
FWIW, My 425 has a B&P pump. I've never heard reliefs operating on it. The engine seems to run out of torque first.
   / More torque for my Power trac? #150
Gravy, Do you have the parts manual for your pump?
   / More torque for my Power trac? #151
That's the pump with the omega sign, right? What year is your 425?
   / More torque for my Power trac? #152
JJ,
I don't have a manual. I haven't even figured out the model number of my pump. The ID plate was evidently left off or removed by PT.
Snow Ridge,
Yes. The Omega was the only way I identified it. I think my 425 is a 2005. It has the Robin engine and the higher torque White wheel motors.
   / More torque for my Power trac? #153
JJ,
Snow Ridge,
Removed by PT, most likely. Did they switch to Bondioli & Pavesi when they dumped the Kohlers for the Robins, or was it at some other time?
   / More torque for my Power trac? #154
I don't really know, but I would guess that they switched engines, pumps, and motors all at once as part of a redesign.
   / More torque for my Power trac? #155
Here is a Steiner manual for a product that also uses a Series 15 pump. In this case, the valves shown behind those caps are check valves, not relief valves. Those part numbers appear to be Steiner numbers, not Sauer-Danfoss or Sundstrand numbers.
The check valves are used to admit hydraulic fluid from the charge pump into the closed loop. From what I can divine about this pump design, it looks like at some point the engineers designed a two way valve to optionally replace the check valves. The two way valves appear to function as a check valve in one direction and a relief valve in the other.
The relief function certainly isn't working on my machine, so I am assuming mine has the check valves like the Steiner.
   / More torque for my Power trac? #156
Stray,
Well I was thinking about this the other day. I was wondering how this has been working for you now that have had this setup for a while.
The truth is that I ran the lower speed set up for a while, found out what it would do and haven稚 changed it back since. (I use quick disconnects to change speeds. It would be great to engineer this with electronic switches) I have relative flat land and the need has not come up for the lower gear. AS I stated before the lower speed set up does increase the pulling and pushing power without harming the pump or wheel motors. You have to operate the PT different than when it is in normal speed mode. It is hard to explain but you can still do the same thing with more push pull power. You just have to do it differently. As far as worrying about the higher pressure, that is only in theory. Actually if anything there is less risk of pressure damage than in regular speed mode. It has to do with wheel slippage and even pressure on all four wheels when best traction is taking place. If I ever have a project that puts the lower gear to good use I値l be sure to post it. Thanks for asking and I will try to answer any question about this as best I can.
   / More torque for my Power trac? #158
Things we know.
12.5 cu in hyd motors, 1500 psi, 16 GPM, 300 rpm. Torque 3000 in lbs
A 25 HP engine can run a 1500 psi pump with a 25 GPM output. Some of that HP will go to the other pumps. So figure about 20 HP for the tram pump, at 1.3 cu in. at 1500 psi, pumping 16 GPM.
A single hyd wheel motor at 16 GPM, at 1500 psi, will turn at 300 rpm, and have 3000 in lbs of torque. 4 hyd motors will have 12,000 in lbs or 1,000 ft lbs of torque.
If two motors are in series, the psi is divided across both motors. If the first hyd motor stalls, what happens to the fluid? Does that give more GPM to the other series circuit.
When you exceed the torque limitation, you force a great resistance to the flow of fluid, and the engine can not handle the blockage, and some fluid will be relieved, and the engine will struggle to compensate, and if you don't let off the treadle, for a smaller flow rate, the engine will die. Keep in mind, you are changing pump displacement, with the treadle.
If the VSP pump was a 3000 psi pump, and you now are sending 3000 psi across two motors is series, and then those two circuits were in parallel, that would change things.
If you put 3000 psi across a 1500 hyd motor, it will probably fail. However, it will run at it's designed pressure for a long time as long as you don't put a large load on it to cause the pressure to increase up to 3000 psi. A relief valve would work, but that is a waste in energy.
If that VSP pump is a .8 cu in 3000 psi pump, a 12 GPM pump, will take a 25 HP engine and that is to supply all 4 wheel motors.
Just something to think about.
Kubota B2301 (A53317)
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56438)
2021 Unverferth...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
