More Toolcat buying questions
   / More Toolcat buying questions #1
Hay Dude
Epic Contributor
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
Looking and searching I'm in the "30k and under" price range.
I have found a lot of 2004-2006 units with 1,500-3,000 hrs for under 20k and a lot of 2009-2011 units with 1,000-1,500 hrs for ~30k.
Truthfully, I like newer lower hour units (who wouldn't), but I also like the idea of saving 10k for some attachments. Is there an ideal "year" to buy? Like for example, in a given year, was the Toolcat redesigned and made much better?
Given reasoable maintenance, is a 3,000hr machine something to be avoided?
These machines look very complex and prone to being unreliable, but running correctly look like a joy to own.
Need advice. Dealers not much help.
   / More Toolcat buying questions #3
I liked my B series except for the stiffer ride and the bucket rollback was not as good as the C series and later.
It lifted more than my F series, had a PTO, and adequate high flow. It was also easier to get to the motor and do service (at least for me).
The ride of my F series is A LOT better.. more akin to my kawasaki mule or Bobcat UTV (polaris) but knowing what I know now, I would have kept my paid-off B series and skipped the F series. It's not that I don't love my F, it's that the B was plenty adequate and aside from the ride and better hydraulic response, the more I use the F (though the controls are "a little" more ergonomic), the more I don't see much difference in power or attachment performance. The F series' engine air filter clogs a lot faster than my b series did (though I had an air pre-cleaner) and if you have a/c, the F series and I assume G too have about the worst placement of the a/c fresh air filter (under the front, right fender). My cab is louder, too, in the F series than it was in the B due to engine placement (further up and to the right). I think the B series was better balanced with the engine placement but maybe I'm imagining it. I do know my F series has a "lean" to the right when you get close to ROC and it falls within Bobcat's "specs" for lean. Frustrating with 1500lbs on forks or when grading with a bucket full of dirt. F series has much colder A/C, though. :)
Sorry I've been away from this thread so long. Still looking as time allows. As in another thread I demoed a Toolcat for a while and liked it. I live in the northeast part of the USA. Most units have a typical rust pattern. Lower doors, lower panels under doors. Access doors to compartments behind doors and maybe other places I may have not seen.
Has this been problematic for any of the owners here on the website? Have you had to repaint or fix rust?
   / More Toolcat buying questions #5
I see a lot of Toolcats with rust issues. The steel can always be repaired and painted. Where I see the most problem is with the wiring. Plugs corrode and fail. Coils swell and burst. Look close!
1832 (A57192)
1832 (A57192)
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
UNUSED FUTURE 44" CAT305 EXCAVATOR RAKE (A57193)
UNUSED FUTURE 44"...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
UNUSED IRANCH 14' BI-PARTING GATE (DAMAGED) (A57193)
UNUSED IRANCH 14'...
UNUSED IRGC40 MINI ELECTRIC GOLFCART (A57193)
UNUSED IRGC40 MINI...
