Spreader More spreader questions
/ More spreader questions #1
WHMOBX
Dayton, Maryland
1954 Ford NAA, 2004 New Holland TC 45 DA
I recently purchased a 3pt spreader form Agri Supply, I believe it is the same as a Cosmo. Anyway to make a long story short, I purchased TSC fertilizer and per the bag set the opening a #3 and the tractor speed at 5 mph. At least one bag of the first 3 that I put in the hopper had a little moisture in it. Not enough, I felt to cause a problem, especially since the spreader has that big agitator in it. Since I have never used a 3pt spreader before, I wasn't sure if what I was seeing being spread was adequate or not. I soon realized it wasn't as the consumption rate was low. I was supposed to be using almost 4 bag per acreas and went over the whole 5 not even using up 4 bags. I got off the tractor an openned up the gates, they were both clogged shut with what looked like black chaulk and there was a large hard "funnel" mass around the agitator. The guy at TSC said that the moisture in the bag should not have caused the problem , that the opennings are probably too small. On #3 both opennings are about 3/8" in the center. All I wanted to do is spread a little fertizer and the whole experience is making me feel a little stupid. Whats going on. I looked a buddies larger Cosmo unit that has the same gates and when open looked about the same. Any help would be greatly appreciated. Bill
Okay, so this ddn't get any replies. How about this. Is there is anybody out there that has a Cosmo or Agri Supply spreader? If so, could you measure the opeening of your spreader gates set on #3? Again, thanks to anyone who could help me out. Bill
/ More spreader questions #3
My Agri-Fab spreader isn't a 3ph, but the fertilizer I bought at TSC last week said to set the number at 5 and the ground speed should be 3mph... just the opposite of what you wrote. The directions didn't say which Agri-fab spreader this applied to.
When I used a 3ph spreader a couple years ago the openings, which I believe was a series a 5 circles, were about 2/5 open. Sorry I can't be more help, but these numbers are only a guide remember.
/ More spreader questions #4
Since we have assembled thousands of spreaders it sounds as if the spreader was assembled incorrectly. Cosmo has both a side gate and a bottom plates delivery, Which unit do you have? Landpride sells Cosmo spreaders and their manual is on line that may help you.
My spreader has two gates or openings and they are on the sides. Thanks for your responces. Bill
Freds, I double checked my numbers and they were right. The TSC guy told me I needed to apply 160 lbs per acre and my spreader chart says 5 mph x gate setting 3=156 pds per acre. ??? Bill.
/ More spreader questions #7
OK, just checking.
I'm hoping to get to play with the 175 lb tow behind spreader I just bought next week. Supposed to snow again this weekend. /forums/images/graemlins/frown.gif Got 500 lbs of fertilizer setting in my FEL just waiting.
I did get to mow the lawn though, today. /forums/images/graemlins/smile.gif First I've really been on the lawn tractor all year.
Yea, I would love to get all the fertilizer down that I have. Enough for 10 acres. Rainy and cold all day here. No snow though. I did get to cut my property last weekend. First time on my new tractor and with the new 6ft mower. More fun than I have had in a while. Can't wait to cut some more!
If you get a chance, could you get me a "visual" measurement of your gates when they are open, either on 3 or 5. Thanks again. Bill
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2017 Ford F-150...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
ROBINAIR MODEL 34788NI AC RECOVERY UNIT (A67714)
ROBINAIR MODEL...
THREE ROLLING SHOP FANS (A67714)
THREE ROLLING SHOP...
2012 CATERPILLAR AP1000E ASPHALT PAVER (A65056)
2012 CATERPILLAR...
Mercury Black Max 150HP Outboard Boat Motor. (A66738)
Mercury Black Max...
