more pressure needed to run tubgrinder
   / more pressure needed to run tubgrinder #1
cowman 10
farmall and international models
I have an old NEW hOLLAND MODEL 390 tubgrinder that I had the hydraulic motor rebuilt. I used to run this tubgrinder with an old IH 806 diesel. Now it won't begin to turn the tub. My son had it over to his place in a neighboring state, and ran it with a much newer Case IH model, and the tub never offered to stop once. My little operation don't justify a high dollar tractor just to run a tubgrinder for 40-50 cows. Any suggestions on increasing pump pressures, etc. ??
   / more pressure needed to run tubgrinder #2
Welcome to TBN
I suggest to utilize a gauge & check your tractors hyd pressure. Has hyd filter been changed lately?
   / more pressure needed to run tubgrinder #3
It's not difficult or expensive to put a higher rated relief valve cartridge in your 806. I'm pretty certain a relief from a 66 series tractor will be rated higher but still safe to install in your 806.
Check your system pressure before and after.
   / more pressure needed to run tubgrinder #4
You can try and get by by trying to boost the pressure, but I really expect that you will end up
replacing the pump. Unless you get real lucky and just a filter change clears up your issues.
RickB did the 806 use two pumps or just one?
   / more pressure needed to run tubgrinder #5
Lou, the 806 had the typical configuration of IH tractors with hydraulic TA’s. An MCV pump for steering, brakes and TA along with a hitch pump for the 3PT and remotes. The PTO unit has its own dedicated pump. I should go back and see if the RV for a 1066 is more than 2000 psi, I bet it is. I’ve seen these older IH tractors that wouldn’t open a round baler gate or fold a 4 star Tedder without jacking up the relief. Not saying this couldn’t lead to a pump as well.
1066 relief is pre set for 2500 psi. That’s the one the OP’s 806 needs.
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2001 Volvo VNL Truck, VIN # 4V4N19JF51N250353 (A51572)
2001 Volvo VNL...
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
Tri-Axle Police Travel Trailer (A51694)
Tri-Axle Police...
