More Info on 7305 power problems
Status
Not open for further replies.
   / More Info on 7305 power problems #1
Chris_J
Here is more information on power problems - maybe you can help me determine if this is a hydro issue or an engine issue. When I set my rpms for 2000 rpms and put it into high or middle gear and then accelerate, the tractor starts to accelerate but then gradually slows down. The thing that I notice is that when I slow down, the motor rpms also go down - way down (500 - 700 rpms). If the hydro filter was plugged (needed changing), wouldn't that just affect the transmission power/speed and not the engine rpms? The other thing I notice, is that it begins to smell hot and pushes a little black smoke (not much - very hard to see). The temp guage shows operating in the green (the needle doesn't even get to the middle of the green).
As far as the filters & fluid, all were changed 50 hours ago.
Maybe this will help spark some other ideas - or maybe stay with filters needing to be changed.
Thanks!!!
Status
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
UNUSED Mobile Expandable Metal Barricade Set (A50860)
UNUSED Mobile...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51219)
2015 FREIGHTLINER...
2011 Ford Fusion SE Sedan (A48082)
2011 Ford Fusion...
Gang Box (A50860)
Gang Box (A50860)
