(More Help Needed) Price Check JD 790...
   / (More Help Needed) Price Check JD 790... #1
TexasOaks
Denton, Texas
In the market
Item Specifics - Tractors
Make: John Deere Fuel: Diesel
Model: 790 Engine Cylinders: 3
Model Year: 2001 Engine HP: 27
Hours: 118 Transmission Type: Manual
Drive: 4WD Condition: Used
Serial Number: LV0790G472046
They are asking $14,000 (Dealer) and I was thinking 12,500 to 13,000 to make it a good deal?
Any opinions apprecaited. Thanks.
Another option... farther away but not too bad..
Year 2000
Manufacturer JOHN DEERE
Model 790
Price $11,250
Location Rogers, Arkansas
Serial Number LV0790G295066
Condition USED
Drive 4WD
HorsePower 28
Hours 488
Asking 11,250 (Private Owner)
   / (More Help Needed) Price Check JD 790... #3
The first machine seems to be priced a bit high ($14K). Does it include the RFM and box blade? Do you need those implements?
I'd offer the $12.5K
The Arkansas machine is also a bit high (IMHO) for a private sale. I assume this includes the cutter. I'd offer $10.5K.
Shippng could make the Arkansas tractor more expensive then the first machine (which I'm assuming is in Texas).
I bought my 790 with 24 hours on the meter. The tractor was a 2003 and I paid $12.5K about 2 years ago. I live in southern PA, the tractor came from a dealer in southern Virginia. Use that for comparison.
BTW, the 70 loader does not have the lifting capacity (weight and height) of the 419 loader (which replaced the 70), or the 300 (which replaced the 419).
If these machines look as good as they do in the pictures, they'll sell fast.
Thanks Roy for the loader info (didnt know that).. Yes, the first one does include both. Did yours come with a rotary cutter when you bought it. What HP is yours? I noticed they range from 34-30. And is it me or does the tractors seem to be cheaper up north?
Will I notice a big difference in the different loaders between 70, 419, and 300? Ya, if the Ark. one would being willing to do some negotiating, I would have to drive down and pick it up. That would be a trailer, I really think we should just buy one, since we really could use one other than hauling around the tractor.
Again thanks Roy for the help.
   / (More Help Needed) Price Check JD 790... #5
TexasOaks said:
Thanks Roy for the loader info (didn't know that).. Yes, the first one does include both. Did yours come with a rotary cutter when you bought it. What HP is yours? I noticed they range from 34-30. And is it me or does the tractors seem to be cheaper up north?
The 790 has had 3 engines. The first was rated at 30 HP (Gross) and 25 PTO HP. That engine was also larger (91 CID vs. 81 CID for the later engines). This engine was replaced in 2001 or 2002. Best word I ever got was the 790 was too competitive with the 4200 and 4300 series tractors, so it was de-rated.
The machines your looking at both have the 30 HP engine.
The replacement engine was 27 Gross HP, 24 at the PTO. That engine was replaced in 2004 or 2005 (I think). That's the engine in my 790.
The current engine is also 27 Gross and 24 PTO HP. I've no idea why Deere went to this latest engine. The only thing I don't like about my 790's engine is the oil dipstick is a pain to get to (the latest engine's dipstick is a lot easier to get to). It's possible Yanmar stopped building that engine for one reason or another.
As far as the loader...that really depends on your intended usage. The 70 loader has a max capacity of about 650 lbs, if I recall. It lifts to about 75". The 419 has less capacity at max height, but lifts 88" (so, at 75", the 419 is stronger then the 70).
All the 790's 3PH capacity is 815 lbs or so, but can actually go higher.
When I bought mine, it was just the tractor and FEL.
Prices do seem to be dependent upon geographical location. It also seems (based upon my review or prices on Machinefinder.com) that used 790 prices have increased over the last couple years. That's not a scientific study...just something I noticed. The lowest prices seem to be in the South East (but I've never looked west of the Mississippi).
Anyway, these are nice machines...old designs though. Nice ones sell fast though.
What are your intended uses?
Mostly 1.5 acre or less food plots, leveling out our dirt roads, moving some dirt around, nothing really that demanding.
   / (More Help Needed) Price Check JD 790... #7
OK, the 790 would be a good fit.
I'd lean toward the closest machine, BTW. If that's the first tractor you described, you'll want the box blade anyway. If you're not going to need that finishing mower, maybe the dealer would be willing to sell the tractor/boxblade combo only.
Oh we will need the mower.
   / (More Help Needed) Price Check JD 790... #9
Then don't wait too long...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 TRUCK (A51406)
2011 INTERNATIONAL...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
