Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,424
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I don't have time to troubleshoot them know.. but tomorrow I will. Symptoms.
Brake controller registering 0.0 when brakes pushed... .. manual push switch registers whatever power dial is set at.. but display dims.
Display normally shows a red dot if no trailer is connected, and is suposed to be 'short proof'..
So I am guessing i have 1 or more shorted magnets... or the breakaway battery is shorted partially and drawing down the power feed to the trailer...
opinions? It's a big tex model.. .. anyone been into one of these.
Do the universal magnets at tractor supply fit them?
If anyone has a link to the breakaway wireing I'd be very thankfull... I *think* it is just a wire from incoming 12v+ and - to a rechargeable battery, and then a wire from 12v+ thru a open switch to the brakes. if the switch closes ( breakaway wire pulls plug out ).. then the switch gives 12v+ tot he brakes... am i on the right track here?
thanks
I'll add that this trailer has been working fine with this truck for a few years.. nothing new has been added or changed... brakes worked fine at start of trip.. I set them and adjusted as soon as I pulled out on the road.
Any help, thoughts, ideas, pointers anyone has.. even far fetched ones, will be much appreciated. ( I'll even take WAG's )
Also.. I have a auxilary ground wire from the tow vehicle tot he trailer that is on a quick attach connector.. so i don't think it is a bad ground issue.
Soundguy
thanks
Soundguy
