montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #1
fredshop2
juneau alaska
case
I would like to know the spec s of the pump and if any ones knows where to pick up a replacement
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #2
Welcome to TBN
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #3
Welcome to TractorByNet :tractor:
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #5
Are you looking for parts?
Do you want to replace that pump with something equal?
What is the HP of the engine driving the pump?
Can you show a picture?
Would you need a two stage log splitter pump to match your engine?
the engine is a 8 hp briggs and stratton I wanted to find a pump comparable I sent the pump no. some body out there may know the spec.s then i can try and locate a pump out there . any heelp would be apreciated skip
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #8
John S. Barnes was purchased by the Haldex corporation several years ago and now recently someone purchased them from Haldex so I suspect information on that pump may be hard to get.
I would check the front mounting features and drive shaft size and then find a pump like J_J references with these same features.
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #9
If the pump above will not fit your pump mount, then select a pump mount from this list, observing the bolt hole pattern.
Most 8 HP engines are 1 in shaft.
You might need to change out the couplings. Lovejoy type, etc.
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #10
oldnslo, Is John S Barnes on the river my state st, or is that W.F. & John Barnes?
PALLET OF SCAFFOLDING (APPROX. 16 PC) (A52706)
PALLET OF...
Galvanized steel fence (A53424)
Galvanized steel...
48" WIDE WOODEN W/ METAL RAILING (A54757)
48" WIDE WOODEN W/...
2016 Chevrolet Sonic LS Hatchback (A55758)
2016 Chevrolet...
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
2024 ATLAS CORPO PACF44 PORTABLE DEWATERING PUMP (A52705)
2024 ATLAS CORPO...
